Regular fuel tank vs. reserve tank question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-30-2007, 10:59 AM   #1 (permalink)
The past 3 days on the New Jersey shore have been great for riding. Let the fun begin.
I have a quick technical question about how the bonneville uses gas from the regular tank vs. the reserve tank.
If I fill up the gas tank, and only run the bike on the regular tank, will the reserve fuel become "old" after a while, or does all the gas mix together when you refill the tank. Probably a really stupid question but thought someone a little smarter than me might know.
Maybe I'm just paranoid but about 1 month after I bought my 2001 bonneville from a guy in PA, the carbs clogged and I had to spend about $650 to get it all fixed. Now I run fuel stabilizer all the time and never want to have that problem again.
Happy riding.
Newbritrider is offline   Reply With Quote
Old 03-30-2007, 11:06 AM   #2 (permalink)
Favourite Bike: 1972 Suzuki TM 250
Loxpump's Avatar
Only one tank and the gas is the same.
Stop Global Whining!
Semper Fi!
Loxpump is offline   Reply With Quote
Old 03-30-2007, 11:12 AM   #3 (permalink)
Favourite Bike: 2003 T100
ohiorider's Avatar
There aren't two separate tanks, therefore all the gas mixes together. The petcock has two fuel pickups. The normal position pickup sticks up higher into the fuel tank than the reserve pickup. When the fuel level goes below the normal pickup and the bike begins sputtering, by turning the lever to reserve, you're switching to the lower pickup, which, because it is positioned lower in the fuel tank, provides "reserve" fuel to the carbs. Summary - there is only one fuel tank on your bike.
Bob
Old 03-30-2007, 11:13 AM   #4 (permalink)
No it will not become "old". It is the same tank. When you switch to "reserve" what you are really doing is switching to a withdraw tube that sits lower in the same tank. Imagine your petcock as having two tubes that come up from the bottom of the tank. The main is longer, so it runs out of gas sooner when you gas level gets lower. When you switch to the reserve you are switching to the shorter tube that sits lower in the tank and therefore still has gas.
Hope that helped.
- David
russd01 is offline   Reply With Quote
Old 03-30-2007, 11:14 AM   #5 (permalink)
Hmm.. I guess I don't type fast enough. Ohio beat me to it
Old 03-30-2007, 12:00 PM   #6 (permalink)
SpeedyPete's Avatar
That's OK Russ - you still had the right answer. Good work and gold stars all around.
Newbrit - save the stabilizer for next winter, you don't want that gunk messing with the oil on the cylinder walls. That would be worse than a carb clean. Now get back to the boardwalk will ya!!!
P
I have heard the song of the Sausage Creature!
SpeedyPete is offline   Reply With Quote
Old 03-30-2007, 12:21 PM   #7 (permalink)
Favourite Bike: '06 T100, Black n' Red
KingBear's Avatar
Biggest problem - runs out too soon
Newbies, be sure to reset your trip odometer every time you fill up. You should hit reserve around 130-145 miles.
KingBear is offline   Reply With Quote
Old 03-30-2007, 12:24 PM   #8 (permalink)
It might make ya feel better.....
- if -
you go out and buy some Seafoam (marine) additive and add about four ounces to a FULL tank of gas. Run her out, run her hard a few times, run her about 15 miles beyond switching over to reserve.
(I do this to everything I own about every 2,000 miles. It just..... makes me feel better.)
----- Sa-watdii Thaiumph! -----
Olderyoungster is offline   Reply With Quote
Old 03-30-2007, 12:37 PM   #9 (permalink)
Favourite Bike: 2005 Aegean Blue Triumph Bonneville
lindsayt's Avatar
Other Motorcycle: 2005 Ice Mint Green Genuine Stella
Right. When I'm going on nice, long rides I get 130-145. But in town I get maybe 100. I've been shocked at what a difference there is between in-town and country-cruising mileage. Course, I live in the urban core and spend a lot of time doing the stop-and-go thing, and my commute is really short so I spend as much time warming up the bike as riding it on my daily commute. Still, 100 miles to reserve is annoying.
I only have 1500 miles right now - I'm hoping that with more miles the mileage will get better in town.
2005 Aegean Blue Bonneville - Intiminators and Thruxton preload adjusters up front, Ikon 7613s in the back, otherwise stock
2012 Azzurro Fiat 500 Sport
lindsayt is offline   Reply With Quote
Old 03-30-2007, 01:18 PM   #10 (permalink)
MAR
Favourite Bike: Thruxton
Other Motorcycle: Ducati 916
Extra Motorcycle: Aprilia Falco Laverda Mir
I always get about 105 miles before I go to reserve regardless of the type of riding it is. Yes this is annoying!! I usually avoid going to reserve altogether. I read on another post that it runs empty after about 15 miles because there is only one peacock and there is fuel left on the other side of the tank.
Anyone else experience this?
"What are you rebelling against?"
"What have you got?"
MAR is offline   Reply With Quote
Fuel Tank Question argie Classic, Vintage & Veteran 6 01-14-2008 04:22 PM
07 fuel tank question argh Sprint Forum 6 09-21-2007 01:31 PM
Thunderbird reserve fuel tank Andyman Hinckley Classic Triples 3 04-26-2005 01:06 PM
Sprint ST Fuel Line Question (fuel tank to/from fuel rail) Sprint Forum 7 01-26-2005 10:23 AM
Fuel light and reserve tank kaosj Daytona Deliberations 6 05-08-2004 07:47 PM
