Old 03-28-2007   #1 (permalink)
Favorite Bike: 2005 Aegean Blue Triumph Bonneville
lindsayt's Avatar
Other Motorcycle: 2005 Ice Mint Green Genuine Stella
So I got the knee pads yesterday and will be sticking them on some time soon. My thought was to put a little isopropyl alcohol on the sides of the bike so I have a little slip before they stick, so I can position them right. Any tips or tricks to getting them aligned perfectly? I suspect this is yet another task that would be easier with the center stand...
38% rocker, 30% mod.
lindsayt is offline   Reply With Quote
Old 03-28-2007   #2 (permalink)
Loxpump's Avatar
I made small marks with a pencil to align them. Marks wipe right off afterwards.
Stop Global Whining!
Semper Fi!
Loxpump is offline   Reply With Quote
Old 03-28-2007   #3 (permalink)
make lines on the tank with masking tape. try and measure it out, or use reference points so its even on both sides.
trav13 is offline   Reply With Quote
Old 03-28-2007   #4 (permalink)
5bassman's Avatar
I just installed mine and thought I had them even but they weren't. So I heated one up with the hairdryer and peeled it off and put it on lightly and do this several times until my reference points were right then I pressed it down tight and their fine now!
2005 Triumph Bonneville Black
5bassman is offline   Reply With Quote
Old 03-28-2007   #5 (permalink)
Just about impossible to see both of them at the same time so even if they are a little off - the only one to know is you... yea, that will keep you awake at night.
For a good stick, get the wax off the tank, degrease. get the tank warm (carefully, duh) press on. Bang with your fist, alot, (without denting the tank, duh)
merlin is offline   Reply With Quote
knee pads gandy dancer Twins Technical Talk 18 02-08-2008 09:26 AM
Knee pads Deacon Twins Technical Talk 28 01-11-2008 12:13 AM
Knee pads decobike Twins Technical Talk 12 07-25-2007 11:35 PM
Skateboard knee pads used as knee sliders? Max_NYC Speed Triple Forum 4 04-19-2007 01:48 PM
knee pads rickj Hinckley Classic Triples 8 08-30-2006 04:43 PM
