What do you clean your chain with? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-25-2007, 10:19 PM   #1 (permalink)
Guy behind the parts counter at the nearby japanese motorcycle delaer recommended brake and clutch cleaner. I know a lot of folks use kerosene. Is brake and clutch cleaner too harsh? Will it damage the o-rings in the chain?
BTW, Triumph dealer is WAY on the other side of town - that's why i by stuff like this at the Honda place.
Go Red Sox!
2005 Thruxton
2007 R1200RT
ThruxtonMI is offline   Reply With Quote
Old 03-25-2007, 10:28 PM   #2 (permalink)
Favourite Bike: My old Bonnie
doctorjay's Avatar
Other Motorcycle: Triumph Thunderbird SE
WD 40 to clean...rub down with an old rag, then PJ1 Blue chain lube....Do all while warm and wipe excess to avoid splatter every 500 miles...P.S. I'd rather be riding than cleaning a freakin' chain...Oh Well!!
Thriumph Thunderbird SE 2010
doctorjay is offline   Reply With Quote
Old 03-25-2007, 10:29 PM   #3 (permalink)
doctorjay's Avatar
Sorry, your from Michigan....forget all that stuff.....Go Buckeyes!!
Old 03-26-2007, 12:56 AM   #4 (permalink)
WD-40 and a rag.
10860 is offline   Reply With Quote
Old 03-26-2007, 09:08 AM   #5 (permalink)
On 2007-03-25 22:56, Bonafide wrote:
WD-40 and a rag.
Ditto. Gentle wire brush if there's any rust.
[ This message was edited by: setts on 2007-03-26 07:09 ]
setts is offline   Reply With Quote
Old 03-26-2007, 10:20 AM   #6 (permalink)
Favourite Bike: 2005 Aegean Blue Triumph Bonneville
lindsayt's Avatar
Other Motorcycle: 2005 Ice Mint Green Genuine Stella
So what about using the chain lube itself to clean the chain? Repsol is very thin, and in combination with a rag and grunge brush, it seems to do a good job as a cleaner, as well as the lube. Spray, scrub and wipe, then spray again, voila! Is there a reason not to do this?
2005 Aegean Blue Bonneville - Intiminators and Thruxton preload adjusters up front, Ikon 7613s in the back, otherwise stock
2012 Azzurro Fiat 500 Sport
lindsayt is offline   Reply With Quote
Old 03-26-2007, 11:28 AM   #7 (permalink)
KEROSENE! It's CHEAP! won't damage the o-rings. WD-40 has been accused of causing rubber to deteriorate. I personally don't know if that's true or not, but Kerosene is cheaper and works very well!
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
CYNCRZR is offline   Reply With Quote
Old 03-26-2007, 02:14 PM   #8 (permalink)
wonderdog's Avatar
Clean the chain???
Never.
Eggs and bacon. A days work for a chicken, a lifetime committment for a pig.
wonderdog is offline   Reply With Quote
Old 03-26-2007, 02:29 PM   #9 (permalink)
Kerosene.......
I plan on using WD-40 to keep my chain clean & shiny after I clean it real well with Kerosene. Then I'll throw the Grunge Brush away as it advised against by those 'in-the-know' NOT to use a steel brush on our chain.
I LOVE the appearance of a pretty (clean & shiny) chain, thus the WD-40 approach. However I'll still spray Bel Ray Clean Chain "Wax" down the middle of my links while they're hot, letting it sit overnight. But unlike my practice of past, I'll follow through with the WD-40 & rag swipe on the sides of my chain.
Someday, I'm gonna git me one dem pertty Gold chains for my bike....! Keeping it clean and blingy with WD-40.
[ This message was edited by: Olderyoungster on 2007-03-26 12:32 ]
----- Sa-watdii Thaiumph! -----
Olderyoungster is offline   Reply With Quote
Old 03-26-2007, 04:46 PM   #10 (permalink)
Kerosene. WD40 would probably work because it's so similar to kerosene. BRAKE AND CLUTCH CLEANER?? You gotta be kidding. Ignore anything else this guy told you. B&C cleaner is strong stuff, likely to remove or damage paint anywhere it's oversprayed, and you won't find it close to the o-rings on my chain. If I use it, I spray it on a rag (away from the bike), and then carefully wipe down the brake rotor with the rag, keeping the rag away from anything but the rotor. Using B&C cleaner on your chain is kinda like washing your face with a Brillo pad--it'll work, but . . . I think shops use B&C to clean oil off engines when they're working on bikes. I once saw them spray a bunch of it around my T100 engine then blast it with compressed air. It cleaned it alright, but I told them never to do that again to my bike.
2005 T100
Best way to clean and lube a chain? Trophy1298 Trophy 4 08-09-2006 12:17 PM
BEST WAY TO CLEAN A CHAIN BullClark Maintenance & Workshop Talk 17 02-07-2006 01:10 PM
how to clean chain? boostedpirate Speed Triple Forum 15 09-11-2005 07:20 AM
How to clean chain ? Sprint Forum 9 09-20-2004 11:22 PM
Best way to clean chain? Serious_Dave Maintenance & Workshop Talk 14 09-21-2003 04:26 AM
