No, it is NOT "normal". How many miles do you have on bonnie? If the rear pads rub that much, they will wear out in a few thousand miles. Some have said their rear pads were gone after only 4000 miles. If you have another dealer within 75 miles, I would suggest taking it to them unless you want to fix it yourself.
Larry
Larry
