Hi everybody
i just bought an extremely expensive pair of spacers and end caps from France. To shorten my forks by 22mm in the form of the Mecatwin fork lowering kit..
So I'm determined to do it this way.
The spacers go on top of the stock springs to add a little more compression I guess. The caps tidy up the exposed fork ends.
I have Hagon 320mm Road shocks for the back, so the bike will be lowered pretty symmetrically.
However I'm thinking of going with Hagon progressive springs as I've heard very good reports and It's also likely that my suspension will be more of an equal match between back and front.
Has anyone used this Mecatwin Kit before?
(There stuff is know for expense but has a good reputation).
Will I need to add the internal spacers from the Mecatwin kit as well as the Hagon progressives?
Or should I leave them out?
I'm thinking about the fork travel here.
Any thoughts gratefully received.
Jon (UK)
This is what I'm on about. The Mecatwin Fork lowering Kit.
