Shop stand - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-25-2007, 09:32 AM   #1 (permalink)
I used some surplus 1-1/2" OD tubing to fabricate a simple shop stand that temporarily attaches to the factory center stand frame tabs. "Version 1" shown below has the uprights on the outboard side of the frame tabs. It works well, and is very stable. With the telescopic riser tubes in the "up" position, there's plenty of clearance to allow blocking the frame up for easy front wheel removal. I'm going to weld up "Version 2" today with the uprights positioned inside the frame tabs....it will be a little easier to install and be useful also on Thruxtons where the exhaust is tucked in a little closer to the frame in that area.
The floor jacks are nice, so long as you're careful not to squash your oil filter or knock the bike off of them, but this little home fabbed tool is light and easy to use, takes up virtually no storage space and best of all......free.
[ This message was edited by: Kevin57 on 2007-03-25 07:36 ]
2007 Goodwood Bonnie, AI removed, evap canisters removed, bafflectomy, fork gaitors, M bars, 19T sprocket, America drivers pegs (no offset), knee pads, checkerboard tank stripe, gold seat logo, rear signal relo, silver cam cover, "8-ball" choke pull.
Kevin57 is offline   Reply With Quote
Old 03-25-2007, 10:20 AM   #2 (permalink)
Very similar to this one that I have, and which works just great.
Page Title
ChrisV is offline   Reply With Quote
shorter side stand (kick stand) ? TriumphTT_2 Triumph SuperSports 6 06-07-2007 07:04 PM
center stand or rear wheel stand? SlackCat Speed Triple Forum 16 05-08-2006 03:53 PM
rear wheel stand (paddock stand) for TBS Hinckley Classic Triples 5 08-29-2004 02:43 PM
Paddock stand vs. center stand questions Solace Sprint Forum 6 04-01-2004 10:31 PM
Stand/Lift for shop work mbernier Maintenance & Workshop Talk 35 10-22-2003 02:08 PM
