speedmaster improved? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 03-25-2007, 09:06 AM   #1 (permalink)
Hi I run a 2003 speedmaster and was wondering whether the later model with slightly larger engine is significantly better. Has anybody who has updated any comment?
[ This message was edited by: traction on 2007-03-25 07:10 ]
PC
traction is offline   Reply With Quote
Old 03-25-2007, 11:58 AM   #2 (permalink)
It's simply got different cams that were designed to deliver more low end torque at the cost of top end HP. The extra CC's matter little if any i'm sure. Is it better? Depends on what you like. I haven't ridden both, but given the choice I'd opt for the low end torque, so i'm glad to own the 865. It's especially important if you want to gear up which many including myself have done. I geared up 2 teeth on the front and one on the rear for a considerably benefit in RPM/MPH. I can now cruise at speed much more relaxed. And the bike still pulls hard at the top and so i don't feel i lost anything over the stock gearing or the 790 engine. That said, the difference is probably not worth worrying about if you had your eye on a bike with one engine or the other.
But i'll take every little bit i can get because torque is king for me. Unless you are always winding her out thru the gears, torque is much more usefull since you use it every time you let go of the clutch on the street. So i'm glad to have the newer engine even if the difference is minimal.
Old 03-25-2007, 07:30 PM   #3 (permalink)
Favourite Bike: 02 Triumph Bonneville Ame
Just do what I did and put in the 904 Big Bore. Problem/discussion solved!
I'm wearing boots of escaping! I'm wearing boots of escaping!
Wyrm74 is offline   Reply With Quote
Old 03-26-2007, 11:11 PM   #4 (permalink)
B02S4's Avatar
This doesn't directly answer your question but is still relevant to the discussion...in my back to back comparison of a 790 Bonnie (jetted & piped) & stock 865 Thruxton I couldn't detect any seat of the pants difference in power between those two. If anything, the Bonnie was subjectively stronger. What Dazco said above is the bottom line.
B02S4 is offline   Reply With Quote
Fuel Cat In Petrol Tank - Improved Economy robnobrakes Club Cafe' 1 05-28-2007 09:17 AM
improved definitions Bundyon_Jen Biker Hang-Out 9 04-28-2007 09:50 AM
New & improved...now with cafe-correct bar-end mirrors. TroyH Club Cafe' 12 12-17-2006 02:50 PM
Gas Mileage Improved w/Flyscreen & 89 Octane Fuel Liontari Twins Talk 8 05-27-2006 07:02 AM
Improved handling Spooner Hinckley Classic Triples 6 09-01-2005 10:04 AM
