Check for clearance between the assy (that holds the front brake reservoir, brake lever, starter button, emergency kill switch, etc.) and your throttle grip. Loosen the allen bolts holding the assy and slide it away from the throttle grip if needed. Some have had this problem. There should be about 1/8-->1/4 inch clearance.
Larry
Larry
