Old 03-23-2007   #1 (permalink)
I am wanting to drill the slides per jenk's but am wondering if anyone had anything negative to say about it before I took the plunge as it is a non reversable deal. Also, for those who did it, did you just use a hand drill using the hole for a pilot? Any feedback positive or negative is appreiciated.
AVMECH is offline   Reply With Quote
Old 03-23-2007   #2 (permalink)
Favorite Bike: '06 Bonneville Black
Other Motorcycle: '89 FXR
If your concerned about not being able to reverse the end result by drilling the slide why not just fit a lighter spring?
Accomplishes the same end result in he slide lifting faster, and it's reversible.
Hated By All....cause thats just how it is.
SCCTrim is offline   Reply With Quote
Old 03-23-2007   #3 (permalink)
TCL
Favorite Bike: Triumph Bonneville T-100
TCL's Avatar
SCCTrim, maybe an elementary question, but do you have a part number for the lighter spring? I am having the throttle debate myself, but don't know what spring to buy to try it out. Thanks.
Death or Glory
Rides a 2007 T-100
TCL is offline   Reply With Quote
Old 03-23-2007   #4 (permalink)
bonnevillebilly's Avatar
I drilled mine out to 9/64" on a small drill press.
It went through easy, it is a very thin wall.
I'm sure you can do it with a hand drill.
I had on problems and, I noticed a better a much better
throttle response.
Bill
2001 Bonnie
1976 Bonnie
bonnevillebilly is offline   Reply With Quote
Old 03-23-2007   #5 (permalink)
Sorry, I have no idea of the part # but I'm sure if you took the springs to a shop they could hook you up.
I opted for better throttle response in the form of Mikuni HSR 42mm carbs :-)
Old 03-24-2007   #6 (permalink)
Altering the holes and the spring weight are different and should not be confused.
The spring controls the height of the needle the hole controls the speed that the slide gets to the particular height.
Why do you want to drill the holes?
It will not release hidden HP
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
DickBender is offline   Reply With Quote
Old 03-24-2007   #7 (permalink)
TCL
TCL's Avatar
Because we're sick and we're running out of mods! uke:
Death or Glory
Rides a 2007 T-100
Old 03-24-2007   #8 (permalink)
Beter throttle response is the goal, the larger hole allow's the slide to "lift" quicker. Much like a softer slide spring would, or at least you would think so...
Old 03-24-2007   #9 (permalink)
TCL
TCL's Avatar
Talked to the Honda dealership owner today. He said drilling the slide is a good idea and may slightly help a rich condition at low RPMs. He also said that changing the spring is not the way to go. He says that the jetting kits they sell actually come with a drill bit for the slide and that there really are no drawbacks to increasing the hole. Sounds good enough for me, I've got my wrenches in hand. :hammer:
Death or Glory
Rides a 2007 T-100
Old 03-24-2007   #10 (permalink)
So guys,
I am going to show my ignorance it two areas...
1. Does anyone have a diagram/photo/great explaination as to what you are talking about with drilling the slide? I would really like to improve my throttle response and it sounds like this will do the trick.
2. When you guys are referring to Jenk's what are you talking about. I went to Jenk's Bolts, but didn't see anything that looked like it would give advice on this type of thing.
Thanks.
2005 Bonnie Black
jcline8 is offline   Reply With Quote
Drilling the slide????? bung1 Modifications & Workshop Talk 9 09-01-2007 09:03 PM
Slide drilling negatives AVMECH Club Cafe 5 03-26-2007 04:09 PM
slide drilling question sweatmachine Twins Talk 21 08-23-2006 05:55 AM
Thunder Slide , Lightweight Slide ?? FEDCT Club Cafe 0 05-26-2006 08:46 AM
Carb slide balance drilling? sailfish T3 Sport / Touring Forum 25 03-03-2005 11:11 PM
