Trident-Exhausts.comMotorcycle.comBikeBanditAdvanstarMotorcycleShows
Old 03-20-2007   #1 (permalink)
Newbie
I am replacing a crankshaft in my 73 Bonnie. I have split the cases, the left side came off no problem but I can not get the crank to come out of the right side case, the crank and bearing are still firmly attached, is there some trick or technique that I should use to remove the crank. I made a wooden stand to set the case on and then tapped the crank end with rubber mallet with no success, I'm reluctant to use to much force and damage the case. I would appreciate any info anyone could share, thanks.
jcamshaft is offline   Reply With Quote
Old 03-20-2007   #2 (permalink)
bonnevillebilly's Avatar
try this forum. you will get better results.
CLICK
Bill
2001 Bonnie
1976 Bonnie
bonnevillebilly is offline   Reply With Quote
Old 03-20-2007   #3 (permalink)
Newbie
thanks bill, I'll try that, John
crankshaft seal el_nino3 Modifications & Workshop Talk 1 03-26-2007 04:26 PM
Crankshaft Removal T140V jcamshaft Classic, Vintage & Veteran 4 03-22-2007 03:02 PM
Crankshaft failures deller4210 Sprint Forum 2 03-06-2007 12:54 AM
Crankshaft bearing Osara Modifications & Workshop Talk 13 06-22-2004 02:16 PM
Broken crankshaft niteowl955i Sprint Forum 5 03-15-2004 12:53 PM
