Old 03-14-2007   #1 (permalink)
I decided today, they take too long to re-fill on reserve.
sometimes, Triumph does know best, and I will man up and admit this is one of those times.
dinky little stock strainer and pre-formed line going back on asap
G
I just wanted to ride
Old 03-14-2007   #2 (permalink)
..... yeppers, I made the same mistake. And I STILL have it in place!?!?! Someday (soon?) it's coming outa there.
With the auto filter in place, it takes almost a half mile of sputtering at freeway speeds before the reserve kicks in. Prior to installing the auto filter, my technique has been to quickly switch to reserve, yank on the choke for a hot second, *BAM* instant gas feeding my carb's!
Sputtering and slowing for a half mile in the middle lane is no fun, lemme tell you!
- 'Rider' -
Click here for a view of my Member's Album.
FattRat is offline   Reply With Quote
Old 03-14-2007   #3 (permalink)
HiVel's Avatar
Pingel, Pingel ,Pingel!!!!
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Old 03-14-2007   #4 (permalink)
you dont need a pingel. think about this, if you disconnect your fuel line, with the stock petcock, it will drain your tank in about 2 minutes. do you think your engine requires more flow than that?
pingel cost 80 bucks.
G
Old 03-14-2007   #5 (permalink)
Favorite Bike: 06 Thruxton(black)
cafecruzin's Avatar
Location: land of sweeping plains,drought n flooding rain
can someone tell me the advantages (apart from looks) of the pringle petcock
ROD
As is a tale, so is life: not how long it is, but how good it is, is what matters.
Illegitimis nil carborundum
Quot culi, tot sententiae
cafecruzin is offline   Reply With Quote
Old 03-14-2007   #6 (permalink)
I don't have a Pingel, but they are supposed to turn on and off much more freely than the stock petcock. The advertisement that they will flow more fuel may be true; however, you sure don't need more fuel flow than the stock petcock provides.
As far as fuel filters on gravity fed systems, I have never known of a manufacturer using them--but then again I don't know much. The common thing I have seen on gravity fed systems is screens like Triumph uses. :-D I did put a filter on my old Ford 8N tractor because of the rusty tank--you'd think they would have built them better than that in 1952. :-D I haven't had any problems with the filter on the gravity fed tractor; however I try to keep the tank full, and the 8N gets way better fuel mileage than a Triumph. :-D
Larry
Larry
Old 03-14-2007   #7 (permalink)
Favorite Bike: 05 Black Speedmaster
Like Redbird says, we have gravity fed systems and those auto in-line filters are being used in a pressurized situation. The microns of the filter are fine.
How much for a new fuel filter? bundo Speed Triple Forum 8 01-21-2008 02:51 AM
Fuel Filter? ukilme Triumph SuperSports 2 09-26-2006 10:11 AM
Fuel Filter? Aggie98 Twins Talk 19 08-14-2006 09:40 AM
Oil Filter - dont do what I did ! BigVinny Sprint Forum 14 03-20-2006 11:00 AM
Fuel Filter Sprint Forum 4 05-11-2004 07:11 AM
