I have a set of ceramic coated Predators. I will be sending the headers off to be ceramic coated. The coating is supposed to be 2-4 mils thick. I'm woundering if I should have the entire headers coated of if I should mask the end of the headers that fit into the Predators, cross over area, and header/exhaust port mating surface. I would prefer to just coat the whole part but am not sure how dificult it would be to remove the coating if it became necessary (I know the coating is tuff but it looks like a little agressive sandpaper could knock it down without too muck trouble.)
