Trident-Exhausts.comMotorcycle.comBikeBanditAdvanstarMotorcycleShows
Old 03-13-2007   #1 (permalink)
Before my question, let me put a disclaimer in. Most of the bikes I've had in the past had fuel injection and shaft drive. Ok. That said, my '06 Speedmaster has what I can only describe as a lag and a surge. It's had this from day one. I notice this mostly in the lower gears. It's quite annoying. I recently changed my pipes an re-jetted the carbs, but no change. I adjusted the chain - still no change. Is this a normal by-product of carburation versus fuel injection or is something else going on? This happens when I roll off the throttle and roll it back on. Any suggestions?
"NOBODY GETS OUT OF LIFE ALIVE"
joeknows is offline   Reply With Quote
Old 03-14-2007   #2 (permalink)
that response problem dosnt happen to my 2006 bonnie, or my 80 xs650. both have carbs.
cliff
2006 Bonnie Black
1980 Yamaha xs650
alfacliff is offline   Reply With Quote
Old 03-14-2007   #3 (permalink)
I now think it may be drive train play. Maybe I am just not used to the chain and the trans?? Either way I don't like it
[ This message was edited by: joeknows on 2007-03-14 16:02 ]
Old 03-14-2007   #4 (permalink)
Thats the exact symptom i had when running lean. Is your bike a Ca model by chance?
Old 03-14-2007   #5 (permalink)
No. It's not. I don't think it's running lean but better be safe than sorry. I will have to pull a plug and see.
JOE
Old 03-14-2007   #6 (permalink)
Favorite Bike: 05 TBA
ErwinM's Avatar
Other Motorcycle: 1997 GT mountian bike :)
Dosent hurt to check carb balance. mine were out. Balanced them and it fixed it up.
Erwin
ErwinM is offline   Reply With Quote
Old 03-15-2007   #7 (permalink)
Favorite Bike: 05 speedmaster - black
open up the vacuum ports in the slides to 3mm, that will change your throttle response. You might also try a different needle or try shimming your needles.
mag10 is offline   Reply With Quote
Old 03-15-2007   #8 (permalink)
Thanks Guys
Old 03-15-2007   #9 (permalink)
Also you may wanna check your airbox drain tubes. One backfire and the caps can pop off. I found both mine gone a while back. That can cause more intake not to mention unfiltered. Not sure if it could cause enough extra airflow to cause a lean condition, unless maybe it was on the edge already.
Old 03-16-2007   #10 (permalink)
ErwinM's Avatar
I think his year bike is already at 3mm.................
Erwin
On-off throttle response??? dkurtz Triumph SuperSports 13 07-30-2007 02:39 PM
Abrupt Throttle Response swebb Twins Technical Talk 17 12-06-2006 07:12 PM
inaccurate throttle response alastairmcook Tiger Workshop 5 10-22-2006 04:16 PM
Jerky throttle response Whisperinsmith Sprint Forum 13 05-09-2006 06:53 PM
Throttle Response Richard Daytona Deliberations 4 09-08-2004 04:40 PM
