Old 03-12-2007   #1 (permalink)
LIJ
Favorite Bike: 2003 Cardinal Red Triumph
LIJ's Avatar
The owner's manual recomaends something called Mobilube HD 80. Has anyone tried it? Comments? I'm having trouble finding that exact product. Tips?
A Honda-riding friend of mine tells me to stay away from the chain wax and use transmission oil (I think that Mobilube HD 80 is just that). Comments?
[ This message was edited by: LIJ on 2007-03-12 15:38 ]
LIJ is offline   Reply With Quote
Old 03-12-2007   #2 (permalink)
Favorite Bike: Triumph Bonneville (of course)
doctorjay's Avatar
Go back one page and check "chain oil" All described there.
TOR's, AI removal, Polaris bellmouth, K&N air filter, 118 jets, Hagon progressive fork springs, Progressive 440 HD shocks, sissy bar, summer wind screen, union jack brake resevoir
doctorjay is offline   Reply With Quote
Old 03-12-2007   #3 (permalink)
LIJ
LIJ's Avatar
Actually, it wasn't. But thanks anyway!
Old 03-12-2007   #4 (permalink)
doctorjay's Avatar
OK, sorry....Let's talk about Transmission oil/lube....if something happens to the chain, I'd like to stay close to warranty recommendations...With O rings present, a chain lube that is up to specs, synthetic, and clear, suits me fine...Hope my humble opinion helps...
Old 03-13-2007   #5 (permalink)
LIJ
LIJ's Avatar
Of course it helps! The thing is that I was intereted in the Mobilube HD 80. Do you know anything about that?
Old 03-13-2007   #6 (permalink)
Favorite Bike: Tiger 1050
Other Motorcycle: Honda Transalp
I don't think chains and sprockets are covered by the warranty. Neither are brake pads - not for excessive wear anyway. And it would take a pathologist to figure out if you used the wrong chain lube. Don't worry - just use good stuff! Lard not recommended....
Time flies like an arrow...
Fruit flies like bananas
eagle is offline   Reply With Quote
Old 03-16-2007   #7 (permalink)
LIJ
LIJ's Avatar
Has anyone tried the Mobilube HD 80 stuff? Is it the same as Mobilube HD 80W-90?
Old 03-16-2007   #8 (permalink)
rc
hi
castrol chain wax
or pj1 chain lube
tried most found them the best.
got a can of wurth clear chain lube ,good as well ,no spots of oil off any of them.
''some days its not worth chewing through the leather straps in the morning''
just because your breathing ,don't mean your not dead .
rc is offline   Reply With Quote
Old 03-16-2007   #9 (permalink)
I use Dupont Teflon multipurpose lubricant. Comes in 11 ounce can for about 6 or 7 dollars. Saw it reviewed on a bike site somewhere and it has been great. Also works great on anything else in the house like locks, hinges, etc. I think I bought it at Amazon.
Scott
From Winston-Salem, North Carolina, USA
Think you can, Think you can't, either way you're right.
merlotlover is offline   Reply With Quote
Old 03-16-2007   #10 (permalink)
HiVel's Avatar
The DuPont Teflon stuff is great! I switched from lots of other stuff to this and it is clean and really does the trick! I got it at Lowes or Tony Stewarts store. (H-D)
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Chain-chain-chain, installed by a foo-ool mnmrosen Trophy 8 09-25-2006 12:48 PM
Replace Chain and sprockets, still have a tight spot in chain toecutter Sprint Forum 9 09-23-2006 08:25 PM
Speedo-cable lubricant WS Twins Technical Talk 4 09-17-2006 11:16 AM
Chain adjustment? My chain is too slack, cant adjust. roadkill Speed Triple Forum 5 11-22-2005 07:11 AM
Chain Wax vs. Chain Lube Celeste Twins Talk 4 09-01-2005 12:14 AM
