Old 03-11-2007   #1 (permalink)
What kind of oil should I use? How often should it be oiled? Please help..... :???:
bonnienewbie is offline   Reply With Quote
Old 03-11-2007   #2 (permalink)
Favorite Bike: Tiger 995i
As for what should you use it is a matter of personal preference. I choose to use hypoid gear oil. (sparingly)
I find it lubricates and protects well and cheaply. I have tried waxes and sprays but prefer to use gear oil, a little and often. I always apply a few drops and work it in with a rag so as to restrict throw off. The manual says every 500 miles I believe, I choose to do it when it is dry not stick to numbers.
No doubt others will have other ideas, do what you think best and works for you.
"Those who can make you believe absurdities can make you commit atrocities"
-Voltaire
byjingo is offline   Reply With Quote
Old 03-11-2007   #3 (permalink)
I like the white sprays for normal use. On the road, I take along a small squeeze bottle of 90 wt gear oil and grab a paper towel to wipe down the chain. I lube the chain after riding in bad rain or wet conditions or real dusty conditions. The rain conditions happen a lot along the Gulf Coast so I lube a lot more often than every 500 miles.
ChuckT120 is offline   Reply With Quote
Old 03-11-2007   #4 (permalink)
Favorite Bike: Triumph Bonneville (of course)
doctorjay's Avatar
I clean the chain with WD 40, wipe it down with an old rag, then spray on chain lube for o rings...I use PJ blue that I got from newbonneville.com but any will work...stop at a local shop and buy some....Every 500 miles
TOR's, AI removal, Polaris bellmouth, K&N air filter, 118 jets, Hagon progressive fork springs, Progressive 440 HD shocks, sissy bar, summer wind screen, union jack brake resevoir
doctorjay is online now   Reply With Quote
Old 03-11-2007   #5 (permalink)
I do the same as Doctorjay, works for me.
PS (edit) I do the chain after a ride, while it's warm, wipe it down after applying the lube, then I put the bike away for the night. With PJ Blue (at least), this means very little fling-off.
[ This message was edited by: Baltobonneville on 2007-03-12 21:19 ]
Marty
Baltobonneville is online now   Reply With Quote
Old 03-11-2007   #6 (permalink)
I use WD for cleanig too. I really like the wax for lube. No muss no fuss. So far so good 6k on the clock & only 1 adjust
CAPT D
Old 03-11-2007   #7 (permalink)
The wax?? Sounds interesting. How does it work and where do i get some? :???: :???:
Old 03-11-2007   #8 (permalink)
You can get a chain wax spray at any motorcycle shop.
"I spent a lot of my money on booze, birds, and fast cars. The rest I just squandered."
-George Best
BigChiefWoody is offline   Reply With Quote
Looking for oil...and maybe some chain Lube killian101 Twins Technical Talk 1 11-02-2007 12:35 PM
CHAIN OIL INTERVAL GoinPostal Sprint Forum 5 05-30-2007 11:32 AM
chain oil Ski_rat Club Cafe 5 05-23-2007 04:23 PM
how to oil / lube chain NewBikeRider Triumph SuperSports 6 02-21-2007 04:00 PM
oil chain 97TB Modifications & Workshop Talk 13 07-08-2004 01:32 PM
