Old 03-10-2007   #1 (permalink)
I put some new turn signals on my bike today and when I connected the last signal, all signals flashed at the same time. With the two fronts and the left rear connected, only one side would flash, but as soon as I connected the right rear, all would flash at the same time. Any help?
Thanks,
Mike
Scrambler Mods: snorkle and restrictor plate removal, K&N filter, Thunderbike exhaust, CRG Lane Splitter Mirror, Mini Turn Signals, Bonneville Seat, Black Flattrack Bars, Gran Tourismo grips, Re-Jet so far - Thruxton Needles, 1 shim, 120 mains.
mtgarritson is offline   Reply With Quote
Old 03-10-2007   #2 (permalink)
Favorite Bike: 750 commando, 750 Bonnie, Guzzi V7 Sport, 850 Le Mans
Other Motorcycle: BMW R100 RT
You either have a bad flasher unit or the wrong one. Did the kit come with a new flasher? Is the kit designed for a 2 way or a 3 way flasher? What are you using for ground path?
More information please.
Steve, Gear Head at large
:yayyy: :chug: :yayyy:
Uno Para Todos. Todos Para Uno
11B40!!!!
Marilyn, for my husband.
Spyder94 is offline   Reply With Quote
Old 03-10-2007   #3 (permalink)
Retired Legend
sweatmachine's Avatar
your wires to the signals are wired opposite of what they should be. You probably connected black to black, and b/w to b/w...right?
Do it the opposite way and it'll work. I don't recall the reason, but that's what mine did.
Old 03-10-2007   #4 (permalink)
Try checking the wiring to the RR light as the problem only occurs when it is in the circuit. Reversing the wires to that light would cause a problem like this.
2old2growup is offline   Reply With Quote
Old 03-10-2007   #5 (permalink)
Thanks for the feedback. I'll try it out.
Mike
Old 03-11-2007   #6 (permalink)
I had the same problem, turns out the neg of the new lights was the whole light assembly itself.
When I connected both front ones up all 4 would flash on a signal. I insulated the mounting post and mounting bracket with electrical tape and it solved the problem, the same thing my be happening to you.
mshelton is offline   Reply With Quote
Old 03-12-2007   #7 (permalink)
I went with sweatmachine's solution of just reversing the wires on each signal. Worked like a charm.
Gotta love this forum.
Thanks again,
Mike
Old 03-12-2007   #8 (permalink)
Retired Legend
yeah buddy!
Front left turn signals not flashing t3knoid Twins Technical Talk 5 09-06-2007 11:01 PM
flashing taillight modulator Bigman Twins Technical Talk 16 07-10-2007 02:34 PM
Flashing instrument panel? MickyC Triumph SuperSports 7 05-13-2007 09:51 AM
Flashing Lights Legal or NOT doctorwho Tiger Mods & Bolt-Ons 3 06-24-2006 11:33 AM
Newbie Q re: Cars Flashing BlackBeauty Sprint Forum 9 04-04-2005 09:54 AM
