Old 03-09-2007   #1 (permalink)
I wanted to add shims to my needles, I need some pictures.. I don't know if I am supposed to come in from the top or bottom of the carb.. I added D&D exhaust and a 120 Main and removed the snorkel and cut the hole bigger (about the size of the filter in diameter, stock filter) .. I want to add a shim and increase pilot jets to 42.. I will start tuning from there..
<center>http://i14.tinypic.com/2cmxn3k.jpg</center>
technogrunt is offline   Reply With Quote
Old 03-09-2007   #2 (permalink)
Retired Legend
sweatmachine's Avatar
http://www.dinqua.com/Triumph/Shim1.html
Old 03-09-2007   #3 (permalink)
Thank You sooo Much.
Old 03-11-2007   #4 (permalink)
webonnielad's Avatar
The Brit Iron Rebels site has a couple of very useful tech videos on tuning and check out the Jenks tuning notes.
The Links are below.
Jon (UK).
http://www.britironrebels.com/video.htm
http://www.triumph-bonneville.com/images/CJK6.pdf
http://www.triumph-bonneville.com/images/Jet6.pdf
webonnielad is offline   Reply With Quote
Old 03-11-2007   #5 (permalink)
Just as a caution, if you change the pilots to 42's, you may not have to shim at all.
if you put a shim in, then the 42 pilots may be too rich.
just something to look out for
G
I just wanted to ride
Location? STLBB Twins Talk 7 12-29-2007 06:13 PM
would you ever consider shimming in a handlebar convict Modifications & Workshop Talk 6 12-13-2006 04:48 PM
jetting/shimming for dummies? InfX708 Modifications & Workshop Talk 4 08-05-2005 03:16 PM
Valve Shimming - Bradford Daytona Deliberations 0 09-28-2004 08:22 AM
Shimming Keihin needles Modifications & Workshop Talk 2 03-17-2003 12:35 PM
