Old 03-07-2007   #1 (permalink)
Hi guys. Well I've had a shoulder injury that kept me from riding for several months and not knowing when it would stop hurting, I never put any fuel stabilizer in the tank. Now my bike runs like $%&# and I am sure that the carbs are clogged. So I'm looking at my spiffy Haynes manual on how to disassemble the carbs and clean them and I'm thinking "I could do that". Now, I should say that I have NO automotive or mechanical experience, but I am pretty handy. I have replaced plumbing and installed instruments, pumps and such on boats, fixed plumbing & electric things around the house and am not afraid to try. So my question is, is this something a reasonably conscientious person can do? My option is to have the bike taken to the dealer who is about a zillion miles away or find a nearby generic bike wrencher. Truthfully, I would like to get to know the bike better so when people talk about re-jetting I wouldn't get that "Huh?" look on my face. So, how tough is it? Also, would it be worth running carb cleaner through it for 100 miles? Does that stuff work?
Thanks, Mike :hammer:
MikeinLA is online now   Reply With Quote
Old 03-07-2007   #2 (permalink)
One more thing. I know that any gaskets or O-rings should be replaced when reassembling. Is there a rebuild kit available from Triumph or can I get this stuff at a parts store?
Mike
Old 03-07-2007   #3 (permalink)
How long has your bike been sitting?
I haven't worked on my carbs yet, but will, eventually. It seems like quite a few people here do fiddle with their bike quite a bit, so it can't be too hard.
BlueBird is offline   Reply With Quote
Old 03-07-2007   #4 (permalink)
Favorite Bike: '06 Bonneville Black
Other Motorcycle: '89 FXR
Get yourself some seafoam, I hear alot of good stuf about it.
Should you need to tear into the carbs, you shouldnt have any real issues. It's like anything else, easier the 2nd time.
Hated By All....cause thats just how it is.
SCCTrim is offline   Reply With Quote
Old 03-07-2007   #5 (permalink)
Dropping the float bowls (four screws each) and removing the main, pilot jet, and idle screw needle are all easy. But be very care full when removing the idle screw needle because there is a little spring and tiny o-ring that will want to fly away.
But before you do that, or even if you do that, buy some good quality fuel system cleaner, dump it in your tank, and ride around some. You might find it clears things up.
Jimbonnie is offline   Reply With Quote
Old 03-07-2007   #6 (permalink)
yeah, i'd dump all the old gas then run clean fuel and seafoam thru it-use the small drains on the bottom of the float bowls to get rid of all suspect fuel
G
I just wanted to ride
Old 03-07-2007   #7 (permalink)
Yeah, betcha you really don't really have to do this teardown. I didn't 'have to' alot of things, just couldn't help myself.
merlin is offline   Reply With Quote
Old 03-07-2007   #8 (permalink)
I think it's easy to work on the carbs. Important thing is to work in clean conditions and pay attention to how things come apart so you can put 'em back together correctly.
So long, and thanks for all the fish!
DrEnglish is offline   Reply With Quote
Old 03-07-2007   #9 (permalink)
grayghost's Avatar
A few tips if you are going to do this (especially the first time)
1. No interruptions (kids, neighbour chatting in your ear)
2. Good light
3. Spread out a white shop towel and put everything carefully laid out in the order you removed them.
4. Do not rush
Most mistakes I've made over the years have been through distractions or rushing.
Enjoy it! :-D
" No.....your other left" (Memories to when I was a Motorcycle Instructor)
grayghost is offline   Reply With Quote
Old 03-07-2007   #10 (permalink)
Favorite Bike: 2005 Bonneville T-100
Panthermark's Avatar
Carbs are not bad....but when it comes to working on bikes...
There are no such thing as hard jobs....only time consuming jobs...
Mark
A very hard Forum to work out postnote Hinckley Classic Triples 24 12-27-2007 08:22 AM
Can't get carbs right tri650 Classic, Vintage & Veteran 8 07-21-2007 08:22 PM
How hard would it be to get this to work on the Triple? OG-MOON Speed Triple Forum 11 12-09-2006 03:53 PM
Hard left, hard right jimmyc Twins Talk 3 08-15-2006 09:08 AM
Trophy CV carbs at varying altitudes.... EFI vs CV Carbs TiggerTwo Trophy 9 01-17-2006 01:07 AM
