AdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.com
Old 03-01-2007   #1 (permalink)
Scrambler owners, with fly screen.
I need to know how to remove the bolts securing the wire guide, there is hardly any space in there. What tool did you use and did you have to remove the head lamp? .
Thanks.
f650blue is offline   Reply With Quote
Old 03-01-2007   #2 (permalink)
Favorite Bike: Scrambler
panthercity's Avatar
Other Motorcycle: R1150RSA
Extra Motorcycle: R1100RSA
Use a hex (allen) wrench to remove the headlamp from the shell.
IIRC, a 12mm wrench removes the headlamp shell bolts. The bolts go through the headlamp bracket, a spacer, a rubber damper pad, the shell then a captive nut (with the wire guide) inside the headlight shell.
Bob AMA #162726 LPR #54
`02 BMW R1150RSA
`06 Triumph "Scrambled"
panthercity is offline   Reply With Quote
Old 03-02-2007   #3 (permalink)
Its a fiddly job and you need a set of torx keys to undo and remove the wire holding bracket and do up the bolts for the screen.
I needed to add some rubber washers for to the screen mounts as they were not in the kit - I used thick rubber tap washers.
Cahn Fahn ya cahn
Davorallyfan is offline   Reply With Quote
Old 03-02-2007   #4 (permalink)
johnyC's Avatar
f650blue,
Not for the first time, I did it the hard way. Well, it seemed easier to me in the long run. I pulled off the top yoke because I couldn't get my sausage fingers in to do the bolts up nice and tight.
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
Old 03-02-2007   #5 (permalink)
Panthercity, Davorallyfan and JohnyC.
Thank you.
That is exactly the information that I need to install the screen.
JohnyC, I too was about to remove the yoke but decided to ask in here first.
Now to the store to get some torx keys and extra rubber washers in case I need them.
I appreciate all your advice.
Old 03-04-2007   #6 (permalink)
how'd it turn out---is the flyscreen worth the price??
crashcrawford is offline   Reply With Quote
Old 03-04-2007   #7 (permalink)
Favorite Bike: 904 Bonnie/Daytona 675
Brooksie's Avatar
Pics?
Brooksie is offline   Reply With Quote
Old 03-05-2007   #8 (permalink)
Yes and no.
Yes it creates a noticable difference and takes wind off your chest and looks neat IMO (highly subjective).
No in that a bigger screen... say the deflector would probably offer more protection and would not look too out of place either.
I'd say go the ...something cycle deflector screen (U.S.)
Cahn Fahn ya cahn
Scrambler - Dart Flyscreen Randy Langgard Twins Technical Talk 3 01-10-2008 10:21 AM
chain installation psmorgan Tiger Workshop 10 07-15-2006 08:55 AM
Dart Flyscreen (NB) vs National Cycle Flyscreen (Bella) dawgfan Twins Technical Talk 19 07-11-2006 11:22 AM
Scrambler Throttle Cable Binding w/ FlyScreen RGSeeds Twins Talk 3 06-20-2006 09:51 AM
PC installation littlefield Speed Triple Forum 0 05-03-2006 08:35 AM
