Old 02-28-2007   #1 (permalink)
I have a 2005 Bonneville Black, I plan on installing a set of D&D meaphones.. What jet sizes do you guys recommend, I plan on using the stock air box for now....
I bought my Bonneville in December 2006 it was a girl owned bike, It looked like it came off the show room floor with.... 150 Miles on it.... $4,600.00... I probably should have been wearing a mask... So the mods begin..
I left the Ducati world behind.. cost and dealership GONE.. Manchester NH????
Thanks
[ This message was edited by: technogrunt on 2007-02-28 08:51 ]
<center>http://i14.tinypic.com/2cmxn3k.jpg</center>
technogrunt is offline   Reply With Quote
Old 02-28-2007   #2 (permalink)
Favorite Bike: 05 Bonneville T100 B/W
wenzel850's Avatar
Tech,
You are aware that those D&D's are extremely LOUD.
I have a set and I wear a full coverage helmet w/ear plugs and they are still to LOUD.
I just thought I'd mention it to you.
As far as what jetting to use, I have no clue my was done by the dealer when I picked up my bike, and I'm not smart enough to ask such questions.
Quentin
"01-20-2009 I can't wait"
wenzel850 is offline   Reply With Quote
Old 02-28-2007   #3 (permalink)
HiVel's Avatar
About all you are going to get from the D&D pipes is noise if you do not open up the intake with a NARK kit. Then you can start jetting for power, etc. Would recommend you look into the NARK and then go with 135/42 with 2 1/2 to 3 turns out .
Just the pipes is probably gonna be close to stock.
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Old 02-28-2007   #4 (permalink)
I'm not sure I agree. open pipes, 42 pilots and 125 mains and a stock air box runs quite nicely, and an improvement over stock for sure.
you are just jaded :razz:
G
I just wanted to ride
Old 02-28-2007   #5 (permalink)
For your consideration (results/mains may differ):
(I edited the below readings recently when I realized my error... brain fade)
Rip off the snorkle.
Replace the factory air filter (or not) with a K&N or Uni.
Replace the mains with some (*125's) or some *135's,
go for a ride..... and if it sputters between throttle on/off, add a shim or two.
- or -
Stick some Thruxton needles in there, they're cheap!
Try some 125's.
Replace the pilots with some 42's (they're a bear to get out)
- and/or -
Tear into your air box and rip out the divider plate,
put a cheap (smaller) Polaris bellmouth on your intake, or an expensive (bigger) Norman Hyde bellmouth,
and try some 130's.
[ This message was edited by: FattRat on 2007-03-01 13:43 ]
- 'Rider' -
Click here for a view of my Member's Album.
FattRat is offline   Reply With Quote
Old 03-01-2007   #6 (permalink)
I'm running stock airbox, snorkel out, bellmouth on, uni filter, D&D cans. Brent at NB recommended 135 mains, 42 pilots, about 2.5 to 3 turns out. His recommendation was good and the bikes fuel metering seems to be spot on. Runs great.
Randy Lambert
Gyspy MC
1962gypsy is offline   Reply With Quote
Old 03-01-2007   #7 (permalink)
I knew I came to the right place for some great input, I'll order some stuff this week. Thanks it's appreciated.
Jetting Whitehurst Club Cafe 4 12-24-2007 05:07 AM
My jetting needs help itcha Twins Technical Talk 4 05-09-2007 04:30 PM
Jetting? Lion Twins Technical Talk 8 03-16-2007 09:18 AM
The Jetting is done... GrahamC Twins Technical Talk 4 08-31-2006 01:53 PM
Jetting - I don't get it. d2mini Twins Talk 12 09-19-2005 09:02 AM
