Old 02-28-2007   #1 (permalink)
Hey Everyone...Just got a brand new 07 scrambler tonight....I'll post up pics and do a nice formal intro asap but right now I've got problems.
I've read the threads here for a while, lurking till I got my bike and now I have it...have put 2 miles on it and now the gas is jammed. The stock cap was jammed and I got that off finally and replaced it with a locking cap. But in my excitement I forgot to take the threads down a hair or add a dab of grease and now this cap is jammed. I can get it to turn but it makes the ratchet sound in both directions. I can turn it with my hand (tough but can) but like I said it rachets in both directions. Any thoughts?
I'm going to grab some channel locks tommorrow and a rubber ratchet thing that people have suggested here, as well as call the dealer and see if they have a magic solution...but am I f'ed? Ideas?
Thanks in advance...and I'm excited to be a part of this place!
My Art
www.dlozeau.com
Newest Works
My newest works
Clysdale is offline   Reply With Quote
Old 02-28-2007   #2 (permalink)
Favorite Bike: Was 2006 Black Bonneville
oldmanjob's Avatar
Most of us here have gone through the same problem. I would go back to the dealer as long as it is a new bike. You can solve this problem in the future with a Monza Fuel cap from Sel-Motion, just push the button and it flips open, problem solved :-D Oh by the way welcome to the forum :-D
[ This message was edited by: oldmanjob on 2007-02-28 06:24 ]
John 14:6 KJV
Black Bonnie - 06
Looking back to the good old days is not the way out. Looking up to the God of All the Days is. (Vance Havner)
oldmanjob is offline   Reply With Quote
Old 02-28-2007   #3 (permalink)
Retired Legend
sweatmachine's Avatar
DO NOT USE CHANNEL LOCKS!
get a rubber wrench thing for oil filters, or something else that won't scratch the tank!
[ This message was edited by: sweatmachine on 2007-02-28 08:28 ]
Old 03-02-2007   #4 (permalink)
I'm sort-of a newbie myself. I got my '06 bonnie last March. This is my first street bike. I had the same problem the first couple of times I filled her up. Fortunately, I was able to get the cap off.
I figured out that I was just twisting the cap too tight. The only explanation I can think of is the plastic threads of the cap are flexed and bound up into metal threads of the tank. tis only a guess.
Now I just turn the cap until it stops and no more. It seems that the stock cap has a slip mechanism that allows the top of the cap to turn about one and one-half to two turns after the cap is properly seated. If you try to turn the cap any further it binds up the threads. I think its odd to construct it this way rather than a ratchet system that prevents overtightening, but that is the way it seems to have been made.
FATCAT is offline   Reply With Quote
Old 03-02-2007   #5 (permalink)
I would like to retract the statement about the threads.
It might be a rubber seal inside the cap. After i made that post, I realized that sounded a little far-out. Maybe there is a gasket under the cap; I can't remember. I'm going to check it when I get home.
But still, I have had no problems since I stopped turning the cap beyond the the stop point.
Old 03-02-2007   #6 (permalink)
Favorite Bike: 2006 Triumph Scrambler
DrPat's Avatar
Other Motorcycle: 2001 Triumph Bonnie
yeah, look, this petrol cap thing is a bastard initially, I had an early moment of panic some distance from home on reserve... The problem seems to be that rather large square section rubber sealing ring - replace it with a proper 'O' ring (round section) - doesn't tighten up quite so much and put pressure back on the tap. Some lubricant (of course..) helps a bit - vaseline or someting. The problem goes away with use, and usually a worn section in tyour gloves at the heel of your hand will provide enough leverage to crack it. Multigrips with a piece of rag always work as a last resort - cheers and congrats on a great bike - is it green/silver? cheers Pat
Dr Pat
DrPat is offline   Reply With Quote
Intro TimTim Speed Triple Forum 8 10-08-2007 09:33 AM
Hello Intro SprintVFR Sprint Forum 12 10-03-2007 06:32 PM
Just to intro myself WelshWizard Biker Hang-Out 18 05-03-2007 10:23 AM
My intro. Landser Speed Triple Forum 19 12-07-2006 01:15 AM
Ahhhhh .... Warmth! ohiorider Twins Technical Talk 23 10-30-2006 10:41 AM
