Old 02-26-2007   #1 (permalink)
Favorite Bike: 2006 Triumph T100
Other Motorcycle: 1968 Triumph Bonneville
Extra Motorcycle: 1972 Suzuki T500
Hey Guys
Ive fitted TORS 115 mains and i needle shim plus removed snorkle
But Im still getting slight backfire on decel. Am I too rich
Cheers
John
New Plymouth
New Zealand
Nzbiker is offline   Reply With Quote
Old 02-26-2007   #2 (permalink)
Have you removed the Air Injection?
Hogtied is offline   Reply With Quote
Old 02-26-2007   #3 (permalink)
yes sorry forgot to mention that
John
New Plymouth
New Zealand
Old 02-27-2007   #4 (permalink)
done the 2.75 turns on the pilot screw ?. I use Jenks Bolts.
Motorbike-Triumph Bonnie
music -MotorHead
woman - Suzi Quatro (I wish)
mkchev is offline   Reply With Quote
Old 02-27-2007   #5 (permalink)
yep set the idle screw
John
New Plymouth
New Zealand
Old 02-27-2007   #6 (permalink)
err pilot screw
John
New Plymouth
New Zealand
Old 02-27-2007   #7 (permalink)
Favorite Bike: '06 Scrambler
barfito's Avatar
Other Motorcycle: '73 CB350G
Popping on decel is called a "lean pop." It doesn't mean your mains are too lean, but perhaps your mixture (since the bike is essentially falling to idle when you release the accelerator). And it actually doesn't even mean your mixture is too lean, because when your bike is idling it could be perfectly fine. It just means you're creating a temporarily lean condition in the motor when it's falling to idle. To correct it, I'd put the snorkel back in or bump up the pilot jets to 42s.
I'm running TORs, snorkel out and K&N air filter with 120 mains and 42 pilots (plus 19T sprocket). No popping here. Consider the K&N if you're going to keep the snorkel out.
My Vespa ET4 has a Ti-Force exhaust which pops lean on decel occasionally, but after 6000 miles it has suffered no noticable detriment.
Hope that helps.
barfito is offline   Reply With Quote
Old 02-27-2007   #8 (permalink)
bonnevillebilly's Avatar
I would try the 120 mains , It worked for me.
Bill
2001 Bonnie
1976 Bonnie
bonnevillebilly is online now   Reply With Quote
Old 02-27-2007   #9 (permalink)
I am soooo confused about *POP* on decel..... Seems the only bikes I've had that DON'T pop or sputter on decel, are bikes that have a completely stock factory exhaust system..... and even THEN, I use to spray water up the can to encourage burning out the packing and get more 'noise'..... AND then it would sputter on decel'.
So I've given up trying to look for and seal air leaks where my after-market can hooks up to the factory header, I've stopped using "popping on decel" as a symptom significant of improper jetting, and as I continue to read these posts about popping and sputtering, I'm not convinced that a diagnosis can be made over the Internet.
Instead, I've learned to LIKE the popping noise..... makes me sound more Ricky Road Racer!
----- Sa-watdii Thaiumph! -----
Olderyoungster is offline   Reply With Quote
Old 02-27-2007   #10 (permalink)
Loxpump's Avatar
I agree, I like the popping. I think it may have been there before my mods, just more noticeable with the louder pipes. If I want it to go away I just pull in the clutch and coast.
Stop Global Whining!
Semper Fi!
Loxpump is offline   Reply With Quote
Exhaust popping LargeWhite Hinckley Classic Triples 24 03-30-2008 12:47 PM
Popping from Hi mount CF exhaust on decel??? silver955i Daytona Deliberations 5 10-07-2007 09:23 PM
exhaust popping. bgaz Twins Technical Talk 6 07-26-2006 07:57 PM
Sprint '06 Stock Exhaust Popping sprintamx Sprint Forum 17 06-27-2006 10:25 PM
Off road exhaust popping. Saigon5 Sprint Forum 18 05-14-2005 12:37 PM
