Nice job! You've eliminated the Bonneville's one styling que that I've never gotten used to. I guess you have to do the whole thing, pipes AND reverse meg mufflers to get the good look like your bike now has. Stock Bonnie mufflers wouldn't look quite the same angled up!
If one were to go the other way .... straight pipe with no kink, do you think std mufflers/TORs would be scraping the ground in the turns?
Although Triumph has said (I think) that the kink is there to keep the mufflers from scraping, I've often wondered if someone at the factory didn't have an 'Oh S***' moment when they first tried to mount mufflers on their development bike, and then decided to put the kink in the exhaust pipes as a work around?
Again, nice job, and thanks for the washer shim hint. I'm filing this post away for future reference.
Bob
