TOR connected to the header bone! - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-23-2007, 03:51 PM   #1 (permalink)
Just kidding on the title. I am wondering if anyone has seen this before. Im sure someone has. I try to search this site before posting anyhting, but either I am an idiot or the search function is horrible on this forum. I can never find anyhting with it.
Anyway...
I am trying to figure out if this is normal operation or possibly a bad fit on my bike. Where the header pipes connect to my TOR's, I get quite a bit of black residue. It look slike it is blowing back out of the joint, but in a forward direction. I have even noticed black soot on the garage floor. Looks to be when I start her up in the mornings. Is this normal? or do I need to reseat the TOR's? I will try to post a pic of it tonight when I get home.
Soccermasta is offline   Reply With Quote
Old 02-23-2007, 04:16 PM   #2 (permalink)
JG
Favourite Bike: 2005 Thruxton
JG's Avatar
Other Motorcycle: 1984 Honda XR350R
It is probably normal. I found out the first time I took my exhaust apart that my stock mufflers came installed new with a bit of silicone sealant in the clamp area. You could try that, and make sure the clamp is tight enough.
2005 Thruxton
JG is offline   Reply With Quote
Old 02-23-2007, 04:18 PM   #3 (permalink)
Favourite Bike: 2005 Bonneville Black
Lion's Avatar
Soccermasta,
I have a 2005 Bonnie with TORs also, the instructions recommend using high temp silicone sealer for the junction where the header and muffler meet, I did this and have no residue appearing at all...
Joe
Lion
Joe's 2005 Bonnie Black
Lion is offline   Reply With Quote
Old 02-23-2007, 06:08 PM   #4 (permalink)
Thanks for the info guys. I will definately give the sealer a try. Any brand suggestions? I am assuming this can be had at a local parts shop? Autozone maybe?
Old 02-23-2007, 06:13 PM   #5 (permalink)
JG
JG's Avatar
Any brand should do. The high temp silicone is usually red, and can go to 600 °F. I have seen it at WalMart for around 5 bucks. Auto places would also have it.
[ This message was edited by: JG on 2007-02-23 16:14 ]
2005 Thruxton
Old 02-23-2007, 06:42 PM   #6 (permalink)
I've also used the regular "clear" silicone and it also works great. Just glob it on the header pipe, install the muffler, and wipe off the excess.
Jimbonnie is offline   Reply With Quote
Old 02-24-2007, 10:42 PM   #7 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
Any old silicone (pure silicone) will do--it will withstand way more temp than your header/silencer junction sees. I used GE silicone on my old BSA at the header/head junction and it lasted for years when the headers would get cherry red for 6-8 inches.
I don't recommend over-tightening the clamp on the silencer...you can create a problem whenever you need to remove and reinstall the silencers. I do recommend removing the silencers only when you have to remove them as in replace them. For other type maintenance, I try to leave them alone. Remember, you can lower the rear wheel easily by taking the shocks loose at the top and removing them from the mount (you need a center stand or bike jack for this).
Larry
Larry
Header bolt torque / Connecting exhaust to header whodkne Speed Triple Forum 3 04-11-2007 12:44 PM
TOR carbon Can and TOR Tune fitted Today Thefallenone Sprint Forum 3 12-29-2006 11:55 PM
the red-wire is connected to the......... valiantbultaco Classic, Vintage & Veteran 9 11-30-2006 08:34 PM
hose that's not connected PtboSprintSt Sprint Forum 4 10-11-2006 01:23 AM
left header blue rt header gold pupkin Twins Talk 7 06-17-2006 10:37 PM
