Scrambler engine breather....... - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Ontario TourismMotorcycle.comHonda Powersports
Old 02-22-2007, 01:24 PM   #1 (permalink)
Favourite Bike: Triumph
johnyC's Avatar
......is different from older bonnies.
When I pulled my cases for polishing, I noticed that my primary case doesn't have the metal pipe with seals at each end which joins the crank to the breather hose, as earlier bikes have. The breather gubbins on mine is hidden beneath a plate behind the clutch gear, wonder if all the bonnies now have this?
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
Scrambler Engine Guards?? LUKAITIS9 Twins Technical Talk 2 01-09-2008 06:37 PM
06 Scrambler engine oil capacity Brumos Twins Technical Talk 3 09-25-2007 01:03 AM
Engine Breather lovecuba Hinckley Classic Triples 1 04-23-2007 10:15 AM
Engine Breather lovecuba Hinckley Classic Triples 6 04-05-2007 06:49 PM
Scrambler Engine Dressers on a Bonnie? poffypoffa Twins Technical Talk 0 10-14-2006 05:28 PM
