How to access instrument lamps? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearHonda Powersports Ontario Tourism
Old 02-21-2007, 02:38 PM   #1 (permalink)
I'm a relatively new Bonneville owner (DEC 06) and have a quick question.
How do you access the instrument lamps?
It appears that the plastic housing under the lamps comes off by removing the two screws underneath, but thought I'd check before attempting to replace a defective bulb.
Bike does not have a tach, if that matters.
Thanks
swebb is offline   Reply With Quote
Old 02-21-2007, 11:54 PM   #2 (permalink)
JesusHoffa's Avatar
I am not sure if this is the best way oi do it, (probably not) But I Pulled gentally on the rubber boot around the light from underneath(which will pop your lenses free) an voilla. To reinstall i just put the bot back through the hole and pushed the lense back in cussed a little bit and tried again until it worked.
hope that helps
Jesus Hoffa
"It is better to be hated for what you are, than to be loved for something you are not"
JesusHoffa is offline   Reply With Quote
Old 02-22-2007, 12:01 AM   #3 (permalink)
Favourite Bike: My Bonneville of course
Thats about my experience. Didn't seem too easy to break,I would dig in
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
vertwrks is offline   Reply With Quote
Old 02-22-2007, 09:48 AM   #4 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
I just reviewed my tacho kit instructions. The colored lenses come off from the top, you should be able to remove them by prying up. The bulb holders pull out from beneath the instrument panel.
Pretty much as Jesushoffa said.
PS I have the tacho kit instructions in a zip file. If you want to see them for the clear diagrams and instructions, send me a PM with your e-mail address.
[ This message was edited by: Baltobonneville on 2007-02-22 07:50 ]
Marty
Old 02-22-2007, 11:11 AM   #5 (permalink)
Thanks for the help.
Appreciate the feedback.
Tail Lamps - Easy Right? DrewDesign007 Twins Technical Talk 13 01-03-2008 06:31 PM
Mounting Turnsignals under the lamps ssjones Twins Technical Talk 0 11-27-2007 01:02 PM
Motovision Lamps RT Tiger Mods & Bolt-Ons (archive) 2 10-18-2007 11:43 AM
Clock lamps BlueTbird Hinckley Classic Triples 0 09-20-2006 11:54 AM
One Lamp/Two Lamps? Diego Tiger Chat 13 06-22-2004 07:59 PM
