you'll have to remove the fork legs, or the top clamp. Your choice.
I'd remove the fork legs, pull the front wheel and fender, then loosen the yokes and slide the legs out one at a time.
You will have to open the headlight bucket (screws at 4 and 8 o'clock) and disconnect the turn signal wires inside, they are easy to find as they're the only connector with only 2 wires. then unscrew the turn signals from the brackets and pull the wires out.
The headlight brackets slide off the forks, make sure to reuse the rubber Orings at each end.
Good luck!!!
