Hello,
I dropped my bike on it's left side and the gear shifter toe-piece broke off.
:evil:
I taped it back on, and managed to continue on my ride.
I had to drill a hole through the bit of screw stuck in the lever arm, and then use an "easy-out" to remove it. I've replaced the screw (fortunately the lever arm is ok, because it is quite expensive!) and have some questions:
1) The entire gear shifter seems to be a bit loose. It moves back and forth about 2 - 3 mm on the gear shaft that comes out of the gear box - is this normal?
2) The screw that holds the shifter onto the shaft was quite tight. It didn't seem to go in very easily, though I can't see any evidence of threads being stripped. What does yours look like? See the two pics below (excuse theh blurry photos):
Thanks! and ride safe!!
Zaq in NZ
