» Links |
02-03-2007
Hi again guys
I have a 2003 T100 Bonnie 790cc.
I've had it 3 !/2 years now.
I'm a little short in the leg so I'll be lowering the front end by 22mm with the MecaTwin Kit.
I was also thinking of lowering the rear end by 20mm by going from 340mm std shock length to a 320mm shock length with firmer springs to compensate for the difference in ground clearance.
I want to lower the whole profile of the bike as I'm after a street fighter custom kind of look.
Does anyone know whether this will work? or is it untried and inherently dangerous.
Has anyone done this?
I know the fender will clear but is there any thing else chassis wise that I should consider. Any obstructions etc.
Before I spend a lot of money on a failed experiment.
Any advice
Jon (UK)
hi webonnielad i think you will be fine are you useing hagon for your rear shocks good shocks and good price
02-03-2007
I lowered the rear of mine 1.25 inches using Hagon shocks and the front 1/2 inch by loosening the bolts holding the shocks and retightening.
2005 Triumph Bonneville Black
02-03-2007
any pics of this 5bassman?
thanks
randy
Live FREE or Die Trying!
Support the World's Military
02-03-2007
Hi Bassman
Thanks for your reply and the same goes to everyone.
I consider this forum to be the motorcycle club I belong to these days. In a strange sort of way.
How does she handle. do you have any grounding problems and are you still using the stock oil filter?
Do you think I should add a sump guard?
I'm kind of lucky Hagons is only about 26 miles away from me so I'll go see what they have and try em for size.
I like the idea of the stainless Nitro's.
All the best
Jon (UK)
02-03-2007
Team Owner Favorite Bike: 04 Bonnie black
Jon,I had the minus 30mm Hagon Nitro`s on my bike for a year.They require a lot of tuning to get "right",which I was never able to sort out.They are nicely made though,and the high cost shows it.I never had a problem with the oil filter,just the occasional grinding of the pegs and more often the sides of my boots.I have my front forks lowered almost to the handlebars and an 18" front rim too. Be careful with the kickstand touching down,but more important,making the bike WAY more upright when parked,like ,tip over upright I never had any handling issues when in "full drop" mode,but I`m not the hooligan rider I wish I was.  If you just want to lower it a bit to try out, for cheap,just lower your fork tubes yourself,5 minutes,free and try some Speedmaster shocks [1/2 to 3/4" shorter].Somebody in your area might have a set just sitting there that you could borrow for your test. Much cheaper to find out just how much drop you need.Here`s a pic of the Hagons,at full drop,except with the old 19" rim.
02-03-2007
Here's the only pic I could do tonight. Nohandling or dragging problems. No bottoming out of front fender either.
Bonnie
02-04-2007
No dragging ? What not even the footpegs? Mine used to drag on roundabouts with stock height suspension.
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
02-04-2007
Hi Bassman
Great looking bike.
I have a stock rear fender etc and want to ride two up on occasions.
Do you think it'll still work.
Jon (UK)
02-04-2007
Sorry guys getting carried away by all these great bike pics.
The last post of mine was concerning Rodburners bike.
No offence Bassman I posted a comment on yours which is beautiful too.
But Rod man will be able to give me the info I need.
Jon (UK)
