» Links |
01-30-2007
i'm pretty sure i have an air leak somewhere. i still need to spray some carb cleaner around and see if i can narrow it down. if i can't, i'm not against replacing some replacables.
i figure the intake manifolds and clamps are a given, but what else could i go after? any other likely offenders that i could easily replace? the vacuum caps look fine and are on there tight.
Alec
TOR's, AI removed, 115/40, 4.25 & 4.5 turns out, 1 shim, stock airbox/paper filter w/ snorkel
On an '02 the intake rubbers are the likely suspects, they get hard and crack as I recall.
What are the symptoms ?
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
01-31-2007
I've heard (never had to do it but the method seems sound) that to trace an intake leak;
1. Warm up the bike and have it idling
2. Take a can of Ether (Quick Start from an Auto supply store) and spray a LITTLE around each intake rubber boot. VERY VERY LITTLE PLEASE. Keep the vapour away from the air cleaner or you will defeat the test.
3. If the idle changes (increases) you have a leak. Try to tighten the clamps first and then re-test. If it still does it change the boots.
WARNING. Have a fire extinguisher right beside you when you do this!
" No.....your other left" (Memories to when I was a Motorcycle Instructor)
01-31-2007
3.5 turns out still has the engine being racey with a little idle hang on a throttle blip. 3.5 seems like a rich air/fuel mixture for the near stock setup i've got (only change is the TORs, AI removal, and 120 main). When she's on the colder side i'll get lean misfires (maybe from an exhaust valve?), but pretty randomly. bad gas milage, average around 25mpg.
i feel like at idle there is just enough of a leak to give some symptoms in the idle sound/feel, and then when i'm going there is enough of a leak to***** up my mpgs.
she's old enough that the rubbers could stand a change. and i've got to take the whole darn thing apart to do that, so i thought i should go ahead and change whatever else might be troublesome whilst i'm in there..
Alec
01-31-2007
Posts: 209 Extra Motorcycle: '99 SV650 (for sale!)
One other thing to consider- what are your valve clearances like? If they've gotten tight, you can get leakage as the engine warms up. This can manifest itself with symptoms that are quite similar to what you describe.
\"A motorcycle is a tool, not a fashion accessory"
My Bobber
02-03-2007
You can spray wd-40 also to check for leaks and it will not ruin any painted parts.
cwmoss
02-03-2007
It's been my experience that very much of an air leak really shows up as popping on deceleration with the throttle closed--the popping will come instantly on closing the throttle.
You started this thread with the solution to the problem already in mind so it is hard for us to comment much...I'm wondering how long you have had the '02, and how many miles it has on it. Sounds to me like you need to pull the carb float bowls and have a look to see how much dirt is in there...you may not have an air leak but a fuel problem, IMHO.
Good Luck,
Larry
Larry
