the breather runs from clutch side of the bike to the air box. So go to the left side of the bike, put your hand on the top of the clutch cover then reach in further and look on the reverse side of the clutch cover area. Its a black rubber tube - oh, dunno, maybe 1/2 inch wide. It enters the engine in an area you can't directly view from the left side. Once you've located it go to the right side with a flashlight and you can see it enter the engine. No maintenance required other than to assure its there.
