Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.comBikeBandit
Old 01-19-2007   #1 (permalink)
I've dug up a few threads on getting a brighter headlight for the Bonnie, but I ride a Scrambler. I know the housing is a different size, but is it the same part for the bulb?
Someone recommended the Sylvania H6024 bulb (for the Bonnie). Has anyone found a nice (bright) halogen for the Scrambler?
Ben
bkunkel is offline   Reply With Quote
Old 01-19-2007   #2 (permalink)
Look for a sylvania silverstar, if you're OE bulb is an H4 type, than you should be able to pick up a silverstar at an advance auto/autozone etc.. The package specifies use on a motorcycle.
Michael D. Rodriguez
RoundSlide is offline   Reply With Quote
Scrambler Replacement Tires TomS Twins Technical Talk 3 08-03-2006 09:06 AM
Scrambler brake reservoir replacement Happnin Twins Talk 4 05-16-2006 09:52 PM
Ignition off; headlamp on? Sprint Forum 21 05-06-2005 09:44 AM
Xenarc headlamp replacement Triumph SuperSports 11 06-15-2004 05:39 PM
Headlamp help please SteveOOO Modifications & Workshop Talk 7 10-29-2003 04:14 AM
