Old 01-05-2007   #1 (permalink)
LIJ
Favorite Bike: 2003 Cardinal Red Triumph
LIJ's Avatar
It is a bit embarrasing to confess, but I have terrible trouble to get my bonnie up on the central stand. Does anyone have any tips and tricks to share?
LIJ is offline   Reply With Quote
Old 01-05-2007   #2 (permalink)
Its all technique. stand at the left side, left hand on handlebar. put stand down with right foot, level bike and put both feet of stand on the ground.
with right hand, grab the frame triangle where passenger foot peg is.
then, put ALL of you weight on the centerstand tang, pull up with right hand, and up she goes
G
I just wanted to ride
Old 01-05-2007   #3 (permalink)
Favorite Bike: 07 America
Other Motorcycle: 05 T100
I was also told to backup onto a peice of 3/4 plywood try that . I have tried and have never been able to do it. Mikey
mikeyland is offline   Reply With Quote
Old 01-05-2007   #4 (permalink)
bonnevillebilly's Avatar
Do every thing Geoff said and,
Use your leg muscles, push down with your leg wile lifting
up and back with your right arm. Take a deep breath and
blow it out all at the same time.
blow out , push down with your leg ,and lift up and back.
Bill
2001 Bonnie
1976 Bonnie
bonnevillebilly is offline   Reply With Quote
Old 01-05-2007   #5 (permalink)
mase's Avatar
G
I second that. I'm not that big of a guy (5'11 155lbs) and I've never had a problem because I read about this technique on another thread before I even got the centerstand.
I was able to visaulize and do it easy on the first try. You don't need to be the hulk, you just have to finesse it. once you do it the right way, you'll feel it and do it easy everytime.
Paul Smart Replica
52' pre-unit thunderbird bobber/board tracker
69' CB350 cafe
Paul Smith Multi-Union
People50
mase is offline   Reply With Quote
Old 01-05-2007   #6 (permalink)
Favorite Bike: 2007 Thruxton
Other Motorcycle: 2002 BMW R1150R
Extra Motorcycle: 2003 Bonneville
I had a lot of difficulty at first, too. Using the piece of plywood worked for me. After using it a few times, I was able to lift the bike up onto the stand without the wood.
The trick (for me), is to not pull upwards on the frame triangle but at a more-or-less 45 degree angle. Think of it as lifting up and pulling back (towards the rear of the bike) at the same time.
I hope this helps.
Sal si puedes.
Tlaloc is offline   Reply With Quote
Old 01-05-2007   #7 (permalink)
meatwagon's Avatar
As stated, you really need to use your body weight pushing down on the stand much more than pulling up with the right arm.Stand on it!
Get it on,get it up,keep the beat
and RIDE WITH ZEKE
BIR #132
TonUp Club San Diego
meatwagon is offline   Reply With Quote
Old 01-05-2007   #8 (permalink)
i must admit that i just figured out the technique on this bike. my lambretta was cake, but weighed about half as much. i really fought with this for a bit before getting it down.
the key for me was being sure that both of the center stand feet are on the ground and that the front wheel is pointing straight ahead. front hand keeps the bike balanced and the rear hand gives just a little tug back and up as you stomp down on the stand. it lifts right up.
but it is an odd feeling at first letting the bike lean away from you until you feel the second foot touch. once you get over that and get used to the weight of the bike, it should go up for you. or maybe not, i guess it may be important that i'm 6'2" 220lbs :-D . my stomp carries a little more "weight" than others .
Alec
TOR's, AI removed, 115/40, 4.25 & 4.5 turns out, 1 shim, stock airbox/paper filter w/ snorkel
Programr is offline   Reply With Quote
Old 01-05-2007   #9 (permalink)
With everyone else said, plus put the bike in neutral.
Toyanvil is online now   Reply With Quote
Old 01-06-2007   #10 (permalink)
Favorite Bike: 01 Sprint ST Turbo
tommyturbo2's Avatar
Other Motorcycle: 01 Bonnie Golden Jubilee
Extra Motorcycle: Suzuki DR400E dirt bike
Having owned 3 Hinkley Triumphs (95 Trophy 4, 01 Bonnie, and 01 ST) I've concluded that Triumph's engineers need help when designing centerstands! In 42 years of riding many different makes of motorcycles, Triumphs have always been a pain to get on their centerstands. I've used every technique I've ever heard of, including the ones spoken of here (which work the best), and the Japanese bikes have the design down right! Hinkley should take note! tommyturbo2
TTG..Three Triumph Garage
tommyturbo2 is offline   Reply With Quote
Central Iowa??? cymoeller Rides & Events 6 01-30-2008 08:43 PM
Central California Riders.... 03SpdFour Sprint Forum 0 01-15-2007 06:58 PM
Any other Scramblers in Central Pa? SCRAMBLEDEGGS Twins Talk 2 04-30-2006 09:25 AM
Central VA dealer? derilict Triumph, Models & Dealers 10 07-22-2005 06:28 PM
new shop in Central PA Jayseal22 Triumph, Models & Dealers 9 05-02-2005 05:51 AM
