AdvanstarMotorcycleShowsBikeBanditMotorcycle.com
ShopTriumph.com
Old 01-01-2007   #1 (permalink)
Thinking about purchasing my 1st torque wrench, can you guys offer any suggestions on quality, price etc. Any photos would be handy too, if possible. Aout to drop oil in Scrambler and dont want to risk stripping drain plug. Thanks,in advance, Rod
aint that the truth
bung1 is offline   Reply With Quote
Old 01-01-2007   #2 (permalink)
Be sure to get one in the range that covers most the torques you need. Most likely one that gives inch pounds, not foot pounds.
Got mine on sale at Harbor Freight for $20. Even if you pay $50 they it still good.
Like you, I believe in using a torque wrench.
black-bonnie is offline   Reply With Quote
Old 01-01-2007   #3 (permalink)
Thanks Blackbonnie, the issue I have found by personel and others mistakes,is that if not straight away,over time just a little tighter each time they eventually strip out.
aint that the truth
Old 01-01-2007   #4 (permalink)
I bought a 3/8" drive from Sears. Its digital, which I recommend. Scale also includes Newton Metre and cost around $65
This looks like the one
Sears digital torque wrench
05 Thruxton
whoa is offline   Reply With Quote
Old 01-01-2007   #5 (permalink)
I have two Sears Craftsman torque wrenches, the "smaller" (of two) 3/8 inch model for most screws and nuts up to 30NM, and the big 1/2 inch model for axle nuts, etc. Ranges on these are marked in inch-pounds or foot-pounds, and they're also marked in Newton-meters.
Don't know if these are available in Australia. They're about US $75 each here and have a good reputation. Others on this forum probably know of some cheaper alternatives that might be just as good.
Unless you're really heavy-handed, the exact tightness of the oil drain plug is not critical. Snug it up and give it one extra pull to tighten and squeeze the washer, and it should be alright. On the other hand, if you get the torque wrench for more critical parts, you might as well use it on the drain bolt.
Marty
Old 01-01-2007   #6 (permalink)
bung1,
This issue came up in a post a few months ago. I deal with torque a lot in my line of work. Overtorquing does weaken threads, especially the two threads at the beginning of the hole that takes most the thread load. It is not evenly distributed as most think it is.
About 50% of friction is just from the head of the screw pushing into the metal it is attaching and about 35% to overcome thread friction, leaving only 15% to produce bolt load.
Then you have to factor in the metal of the screw, the metal of the female threads and gasket compression desired (if one).
Most people using a torque wrench go to the point of torque and then give another umph for good measure. You should not include the extra umph but stop at the desired torque recommended. Also when you're done with the torque wrench, put the tension down to zero again on it so the spring is not compressed in it over a long period of none use time.
Old 01-01-2007   #7 (permalink)
There have been instances reported of the oil pan cracking due to overtorque of the drain bolt. Seems the casting is very thin near the drain bolt. It think a torque wrench on this bolt is critical...
merlin is offline   Reply With Quote
Old 01-02-2007   #8 (permalink)
Good tip, thanks.
05 Thruxton
Old 01-02-2007   #9 (permalink)
Am now,after a bit of research going to buy a deflecting beam style; Any ideas on brand?
aint that the truth
Old 01-02-2007   #10 (permalink)
Favorite Bike: 04 T100 blue/white (his)
Wooly's Avatar
Other Motorcycle: 07 T100 red/black (hers)
Extra Motorcycle: 1971 Yamaha DT2 250
Bung1,
I bought a deflecting beam wrench after much research and asking people who should know about these types of things.
This is the one I finally purchased and I've been very happy with it, it covers the range up to 160nM which is adequate for our Bonnie's.
W&B torque wrench
They also make a 1/4" drive model that covers the inch/pound ranges and I had previously bought one of these many years ago and it still works well.
Norbar is another good brand to buy in Australia and Sidchrome also market one as well but it is actually made by W&B and is identical to the 160nM model I bought.
Phil.
Wooly is online now   Reply With Quote
Torque Wrench Gwiaz Twins Technical Talk 6 08-03-2007 11:32 AM
torque wrench CCR Modifications & Workshop Talk 11 06-03-2007 08:12 PM
Torque Wrench itcha Twins Talk 9 04-18-2007 12:43 PM
torque wrench ? Colonel_Dorkus Twins Talk 10 05-28-2006 02:14 PM
Best Torque Wrench? MaxH Modifications & Workshop Talk 22 06-07-2005 10:15 AM
