Old 12-30-2006   #1 (permalink)
Taffy
This may have been posted before, but can anyone help. Today during a long ride my bonnie just died on me, I thought it may have been dirty fuel and someone suggested opening the fuel cap, where I was able to start the bike, but continually thought the journey I had to slacken the fuel cap to let air in.
I would say there was an obvious fault with either the breather valve or pipe routing. Is there an easy option to overcome this problem?
Many thanks
Taffy
Old 12-30-2006   #2 (permalink)
Favorite Bike: '06 T100
Sounds like you might need a new gas cap. See your dealer, it should be covered on warranty.
Some people are a lot like Slinkys.
Not really good for anything, but bring a smile to your face when you push them down the stairs.
Big_Rick is offline   Reply With Quote
Old 12-30-2006   #3 (permalink)
dardoonk's Avatar
Check your breather line under the tank.
Click here for a drawing, it is #21
Make sure the line isn't pinched & I guess you could take the valve off to see if it works without it. If you can take the valve off & it runs normally, have your dealer get you a replacement valve.
I've gotten this far in life by refusing to act more than half my age, and I intend on continuing this way.
My Photos
'05 America- Works' suspension, Freaked, D&D's, 150 mains, 42 pilots, TBS needles, 1 shim
dardoonk is offline   Reply With Quote
Old 12-30-2006   #4 (permalink)
Remove the cap and suck on it. No, it's not a joke, the breather valve is in the cap and it's known to get stuck
jojje1963 is offline   Reply With Quote
Old 12-31-2006   #5 (permalink)
Taffy
Thanks everyone, I'll give it a try.
Taffy
Old 12-31-2006   #6 (permalink)
Favorite Bike: 2006 Triumph Bonneville T100
Scrambler900's Avatar
Other Motorcycle: 2006 Triumph Scrambler
dardoonk -
Where did you find that great schematic?
Stay cool, like Steve McQueen
Scrambler900 is offline   Reply With Quote
Old 01-01-2007   #7 (permalink)
4Triumph's Avatar
Scrambler900
Go to this link and then click on your bike. http://www.bikebandit.com/partsbandi...fr~Triumph.asp
4Triumph is offline   Reply With Quote
Old 01-01-2007   #8 (permalink)
Taffy
Looks like it's the fuel cap that's giving me the trouble. That site for the schematic diagrams is fantastic.
Thanks everyone
Taffy
Is there a problem with the crankcase breather? NikosR Sprint Forum 3 03-06-2008 03:50 AM
TT600 oil Problem breather valve Expert help snoopin68 Triumph SuperSports 3 09-04-2007 05:40 PM
Bonneville crank case breather problem - help? draig Twins Technical Talk 18 06-04-2007 11:54 AM
05 S3 Fuel Breather jeffro232 Speed Triple Forum 2 06-17-2005 01:22 PM
Oil in the Breather Problem Tibernot4 Sprint Forum 0 06-17-2005 10:52 AM
