Just did mine as well.. Couple of things (and one as previously mentioned)...
There will be four spots to place a plug... two on each carb, though some may already have one plug on the manifold already (left side).
One will be at the front of the carbs (1 each carb), the others will be on the intake manifold as shown here on my right side
There is one hose that runs between the carbs and is the vent for the float bowl area. You will see a hard line between the two with a opening (if hose is removed), use 5/16 hose from the removed pieces or get a new one and connect and run behind carbs, down frame and below swing arm. You should have two hoses running to the back of the bike. One is the above, the other is the tank vent (or sometimes called overflow).
One last thing... Check your petcock fuel line feed and be sure it is not pinched. I did this when re-installing my tank during a re-jet. It looks like it goes over the carb throttle cables when the tanks is "up" or off, but it goes below.
Hope this helps...
