Installed Pro Com Hi REV box - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-23-2006, 10:29 PM   #1 (permalink)
jamboa2003's Avatar
Now that I installed it. I notice when I put my brake on " front or rear" the taillight continuously blinks till you take the brake off. Any Ideas? You have to brake the right side connection of the stock peice because it is attached to the fender with a plastic fastener that does not come apart. I cut mine off and installed a bolt in its place like the other side has. Oh an I bought the plug and play complete Lucas style taillight and signal set from Newbonneville. Don't waste your money. You may as well buy the parts seperate because it is very difficult to install the taillight if you try and follow their directions or lack there of.. They do not even give you the phillp screws you will need. The lucas style tail lightreally cleans up the rear I must say.I just tried it on for looks so far. I put the stock tailight back on and with the Hi Rev Box the tail light blinks when you apply the brakes.
Jamboa
[ This message was edited by: jamboa2003 on 2006-12-25 20:27 ]
04 Bonnie 904cc Assembled In England, 08 B King,10 650 Versys
Triumphs Gone With the Wind=95 T-Bird,98 1200 Trophy,05 Tiger 955I,05 2300 Rocket,06 Scrambler Assembled in England,06 1050 Speed Triple,06 1050 Sprint,07 1050 Tiger
jamboa2003 is offline   Reply With Quote
Old 12-24-2006, 12:41 AM   #2 (permalink)
357Bob's Avatar
I don't know if this is what is happening but the new tail light might have a flasher bulb in it. Did you try changing the bulb? I have seen some bikes with flashing brakelights. Also headlights. What about the high rev box? You started the thread with it but didn't menttion it. I like mine. I also like the stock brake light.
357Bob
Old 12-24-2006, 02:21 AM   #3 (permalink)
I just installed the same kit with no problems,and it works and looks excellent.The only problem,no directions,and I'm not very good at puzzles so it took me awhile.
POPPE is offline   Reply With Quote
Old 12-24-2006, 01:56 PM   #4 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
Procom high rev box?????????? Sounds like a false subject title to me. :-D :-D :-D :-D :-D
Larry
Larry
Old 12-25-2006, 10:20 PM   #5 (permalink)
jamboa2003's Avatar
Yea you have to watch the tach. I shift at 7k. It feels like it is ready to go way past it with out the rev limiter kicking in. I think it was 7k.Too many bikes and I have not had this one long. What does it red line on the tach dial?7K? Oh and the stock tail light is blinking when you apply the brake . I did not continue to mount the new style light. It sure will clean up the rear end with the Lucas style light..
Old 12-25-2006, 10:23 PM   #6 (permalink)
jamboa2003's Avatar
Poppe
You said you installed the light kit but did you do a Pro COM
Hi Rev box also?The box seems to be what is doing it. Any body install the Pro Com Hi Rev Box ?
Old 12-26-2006, 04:47 AM   #7 (permalink)
WHAT THE!!!, Is anyone else having trouble following this thread, or is it just me? :???:
aint that the truth
bung1 is offline   Reply With Quote
Old 12-26-2006, 11:11 AM   #8 (permalink)
Wrrrrrfff?
So long, and thanks for all the fish!
DrEnglish is offline   Reply With Quote
Old 12-26-2006, 03:40 PM   #9 (permalink)
357Bob's Avatar
Yeah like. You know!
357Bob
Old 12-31-2006, 01:29 AM   #10 (permalink)
jamboa2003's Avatar
If you can't contribute why are you posting?
Air Box Elimination/Tear Drops installed... REVOLT Twins Technical Talk 3 03-18-2007 08:34 PM
EXPERIENCE WITH CDI REV BOX FOR TRIUMPH ocguyocguy Twins Technical Talk 14 01-29-2007 01:31 AM
Installed Air Box Elimination Kit on Scrambler Sid Twins Technical Talk 3 09-29-2006 12:32 PM
pro com eng. rev. limiter toby-tri Twins Talk 5 03-06-2006 03:58 AM
installed pro tapers on my triple Speed Triple Forum 13 12-02-2004 11:06 AM
