If I am thinking correctly the tube your speaking of the airbox drain. Oil gets to the box from the crankcase vent tube. If your getting a lot you may have issues but otherwise it is there to drain goo. I have not even checked mine in.......4000 miles so I can not give you something to compare to.
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
