BikeBandit
Old 12-13-2006   #1 (permalink)
New (to me) Bonneville owner question: Does anyone use a swing arm stand for Bonneville maintenance?
Was wondering if the low slung stock exhaust on my 2002 will allow use of a stand. Most of the stands I've seen online seem to be sport bike oriented.
If yes, do you have any make or model recommendations.
Thanks
swebb is offline   Reply With Quote
Old 12-13-2006   #2 (permalink)
Favorite Bike: 2005 Bonneville T100 (B&W) - Chromed like a Harley
raproe's Avatar
When I got my T100, I went down the road you are trying to go. Things may have changed in 2 years, but when I tried to get a swing arm stand, the exhaust ruled it out.
I solved the problem by making a stand that picks up the center stand bolt holes instead of the swing arm. If you want to try that, there is a PDF file with plans here.
"....by its very nature, a single-tracker is in unstable equilibrium, i.e., it cannot, when stationary, stand up by itself."
raproe is offline   Reply With Quote
Old 12-13-2006   #3 (permalink)
listo's Avatar
Other Motorcycle: 1976 Honda CB550 Cafe
I use a standard Pit Bull swingarm stand on my brothers Thruxton. I place it right behind the brake caliper near the chain adjusters. Not sure if it would fit a standard Bonnie exhaust but it clears the Thruxton without issues.
08' S3 Black
76' Honda CB550F cafe
listo is offline   Reply With Quote
Old 12-13-2006   #4 (permalink)
I can get the bike up in seconds..... to eye level..... for a mere $60.00
- 'Rider' -
Click here for a view of my Member's Album.
FattRat is offline   Reply With Quote
Old 12-13-2006   #5 (permalink)
Fattrat - Got a few questions for you.
Where did you get the lift?
Are any modifications needed to use it under your bike?
Are the boards you placed under the wheels necessary to lift the bike or are they to protect the floor?
How's stabliity once the bike is up in the air?
Thanks
Old 12-13-2006   #6 (permalink)
*I got mine on sale at a Harbor Freight, but I understand that it's one in the same as that sold at Sears.
*None, absolutely none.
*It was in my house while I was building it, so I stuck the boards under it in the event I wanted to move it a bit.... I didn't though.
*Unbelievably stable. I've actually crawled on top of the bike to adjust things..... and I ain't no lite-weight.....
- 'Rider' -
Old 12-13-2006   #7 (permalink)
Retired Legend
sweatmachine's Avatar
Pat, you forgot the best part!!!
that jack costs less than a C-note.
I think mine was 89 bucks at Sears.
Old 12-13-2006   #8 (permalink)
Thanks Pat
Fortunately, there's a Harbor Freight near where I live.
Greatly appreciate the feed-back and assistance.
Old 12-13-2006   #9 (permalink)
Forgot to thank all of you who replied.
This forum has been pretty helpful and I've only had the bike for 10 days or so.
Thanks again.
Steve
Old 12-14-2006   #10 (permalink)
Favorite Bike: 2003 T100
ohiorider's Avatar
Here's my advice.... not sure I'm answering the question! If you're buying a new bike, have the dealer install the Triumph center stand, and finance it with the rest of the bike. You'll probably like it, unless you're one who takes the Bonneville to extreme lean angles. Then, you may not like the stand. However, keep in mind that extreme lean angles do not a fast rider make..... but it does wear holes in your TORs. So, up to you.
At that point, if you don't like the center stand, take it off and put it up for sale at 50-60% of what you paid for it. Someone who is contented to move more slowly through the really tight turns will buy it. You've made more costly mistakes.
I have found I can use the center stand as a fulcrum point, when combined with a scissors-jack .... making it extremely easy to align either front or rear axle mount holes when replacing wheels.
Bob
[ This message was edited by: ohiorider on 2006-12-13 23:16 ]
Swing Arm .... NewMetal Twins Technical Talk 4 05-09-2007 04:24 AM
Pics of single side swing arm rear stand awegs955i Daytona Deliberations 10 04-05-2007 01:11 PM
Centerstand/Jack/Lift/Paddock/Swing arm Stand davewhoz Club Cafe 9 11-02-2006 11:35 AM
what size pin do I need for swing arm stand? Hotmailrules Sprint Forum 1 05-11-2005 06:43 AM
rear swing arm stand Speed Triple Forum 2 08-27-2004 05:27 AM
