BikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.com
ShopTriumph.com
Old 12-13-2006   #1 (permalink)
Favorite Bike: Ducati 916-996-998-1098
Max_NYC's Avatar
Other Motorcycle: Triumph Speed Triple
I'm 6'3'' with a 34-36 inseam. Will a set of rearsets on the Bonnie will make it more comfortable or not? Will I gain ground clearance? Right now with the stock pegs and levers I scrape them too easily...
"Je penche, donc je suis."
Max_NYC is offline   Reply With Quote
Old 12-13-2006   #2 (permalink)
tcb
At your height, I think it will become less comfortable, but will help with ground clearance. However, the sidestand will become an issue next. Also make sure the sag on your suspension is set up at the minimum(25mm), as this will help with clearance issues, too. It is usually set at a higher level than that from the factory.
tcb is offline   Reply With Quote
Old 12-13-2006   #3 (permalink)
Likely, you're waaay too heavy for the factory Bonnie suspension (almost everybody is). There are two things you should consider:
1) Put some better rear shocks under you, and upgrade the springs up front as well.
2) Give serious thought to replacing your shocks with something of comperable height/length as those the Thruxton come with; they're taller.
Have your sag/pre-load/damping adjusted by a pro' and have him explain what you can do to further dial them when you're out on the open road.
Rear sets WILL help to a degree (sans center-stand), it's all about whether you're comfortable riding in a more aggressive position. HEY, Europeans do it all the time!
- 'Rider' -
Click here for a view of my Member's Album.
FattRat is offline   Reply With Quote
Old 12-13-2006   #4 (permalink)
You could hang off the bike more, that would allow you to use less lean angle for a given speed.
Psyched Out and Furious
WANG is offline   Reply With Quote
Old 12-13-2006   #5 (permalink)
I put rear sets on mine mainly fo clearance. The position is more comfortable as I find it easier to lean forward now with my legs tucked under more. I also have some lower bars ordered
I am not as tall as you 5'10"
As Pat suggested Thruxton length shocks with appropriate rate spring.
Before I put rear sets on I used to have the Ikon rears on the tallest preload. Except this makes them too hard on the road as all the softer part of the spring is preloaded.
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
DickBender is offline   Reply With Quote
Old 12-13-2006   #6 (permalink)
Max_NYC's Avatar
1) is done: front dual rate springs and rear Street Tracker shocks by Works Performance.
I don't have a center-stand neither.
btw I'm French...
Old 12-13-2006   #7 (permalink)
Max_NYC's Avatar
I do that quite a lot, it helps of course to use less lean angle. But still...
Old 12-13-2006   #8 (permalink)
Max_NYC's Avatar
Yesx, that's the problem: tallest preload = too hard on the road
Old 12-13-2006   #9 (permalink)
Yeah..... sell off those good shocks, somebody should be anxious to buy them! Then replace them with some taller Thruxton height shocks with single rate springs. And DON'T neglect those fatory springs up front, those things have NO damping!
They say the most aggressive rear sets readily available for our bikes are those made by Raask, I have some on my bike. (I'll see if I have an image that shows how high they are.) I'm pretty comfortable with them, but I stand a mere 5' 2".
About that leaning..... ever since I learned to practice"Pivot Steering", my lean angles have been reduced considerably and my chicken strips are now wider.... but the resulting footprint and above mentioned technique is getting me around those sweepers more efficiently.
A quick & easy fix might be to simply replace your fat factory footpegs with some smaller footpegs.
[ This message was edited by: FattRat on 2006-12-13 17:41 ]
- 'Rider' -
Old 12-17-2006   #10 (permalink)
Favorite Bike: 2003 Triumph T100
I posted a review on the N-H rearsets on this forum. I am 5'11", but have a relatively short 31" inseam. The rearsets work for me, but just barely so. I believe that a tall person might have issues with the minimal space between the footpegs and the seat's top. I'd be inclined to go with the taller shocks and a good set of fork springs. Sag uses up the majority of your bike's clearance when stock...
Scraping pegs richb Twins Talk 14 04-20-2008 08:33 AM
Scraping Scrambler Pegs slapdash Twins Talk 1 08-10-2006 06:25 PM
Scraping the pegs DetroitSlim Twins Talk 10 06-05-2006 08:09 PM
tall guy vs. sprint st Sprint Forum 12 03-01-2005 09:16 PM
Legend Scraping Too Many Pegs Hinckley Classic Triples 5 07-08-2004 07:06 PM
