A few shots of the latest prototype mini-speedo/tach brackets hot off the CNC...
That's the stock Bonneville ignition, with the original mounting tabs removed.
After checking and rechecking all locations & fitment, proceeded to sawing the mounting tabs off the lower section of the ignition body,
then to the grinder for material removal, then sanding & polishing, then drilling and tapping through the upper half of the rather substantial threaded bosses inside the ignition body...
Will post more pics and DIY info as time allows...
Special thanks to Loxpump & rodburner for honest feedback during the
latest round of mini-this & mini-that madness...
Cheers,
D9
[ This message was edited by: D9 on 2007-01-02 21:38 ]
