Sorry to hear that. If the edges are not creased, otherwise theres not much you can do aside from bondo or if it's not to bad having it sanded to level the edges after it's been popped out then and repainted. If it's not creased you may be able to pull it out with a suction cup or there are other ways they can do it. There are kits and such. Do a search. But it's all about the dent and how it is. Do you have pics? Or you may be able to find one on ebay. I've seen a lot of them at 1/2 or less of new, which is around $600. (new that is)
