On 2006-12-08 10:09, rmak wrote:
I called local powder coating businesses, but they want the chrome off the shell first. Plating businesses I contacted consider plating removal a nuisances job so it would be expensive. bead blasting is out because of the thin metal. If anyone has done this modification and/ or has a better way to do it, I would appreciate the help. Thanks.
The chrome can be easily stripped at home...
Get some muriatic acid (swimming pool acid), which is just dilute hyrdchloric acid... Dilute that one to one with water is a bucket large enough to submerge the light bucket in. Attach the headlight bucket to a piece of copper wire and dip it into the solution. Wear some heavy kitchen gloves and safety glasses... In a VERY short time the chrome will be stripped off... You can tell when the finish goes from the "bluish" tint of chrome to a more "yellowish" tint of the nickle substrate under the chrome... Rinse well with water .... You now have the chrome removed... You can further rough the surface with some 150 grit wet/dry sandpaper.
If your local guy has a problem powdercoating it after that prep, it's time to look for someone else..
I reccommend Mark's Powdercoating in Moncks Corner SC... Great guys and they do a lot of motorcycle stuff...
www.markspowdercoating.com
