ShopTriumph.com
Old 12-06-2006   #1 (permalink)
Last night while performing some routine maintenance on my (new to me) 2002 Bonneville, I noticed a small exhaust leak where the header pipe meets the muffler.
I could feel the leak easily with my bare hand (near but not on the exhaust system).
Tried several times to reposition/retighten the clamp, but wasn't able to stop the leak completely.
What else (if anything) can I do?
Any advice would be appreciated.
swebb is offline   Reply With Quote
Old 12-06-2006   #2 (permalink)
HiVel's Avatar
GLUE IT W/ HI-TEMP SILICONE
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Old 12-06-2006   #3 (permalink)
Favorite Bike: My Bonneville of course
Can you hear it? With that type connection I am not sure if it is possible to totally seal it. Of course with high temp silicone you may but my Bubs leak a bit at that junction and the only woes it creates is the bit of smudge I have to wipe off every few hundred miles.
Since there is no gasket I am not sure it was ever intended to pass the air tight seal test.
I have had a dozen bikes and either I have been unlucky of this is normal..... Now you have me thinking........too late in the day for that......
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
vertwrks is offline   Reply With Quote
Old 12-07-2006   #4 (permalink)
Mine does this too. I'm planning to go the silicone route. It's just a smudge...prolly no effect on operation of the bike but it won't hurt to seal it either.
So long, and thanks for all the fish!
DrEnglish is offline   Reply With Quote
Old 12-07-2006   #5 (permalink)
When I changed to Norman Hyde Classic silencers, I was instructed to install the new units with high-temp RTV silicone sealant (red/orange in color) at the joint. Once the clamp is tightened, wipe off the excess and let it dry overnight. It's not really an airtight seal without a sealant. You can find the right stuff at any auto parts store.
2005 T100
Old 12-07-2006   #6 (permalink)
Thanks to all for the feed-back.
Interestingly, one of the exhaust joints is fine while the other one leaks.
Thanks again.
Old 12-07-2006   #7 (permalink)
neither of mine leak. I even put a little soapy water on there and fired it up with no bubbles.
TJ
caspianthruxton is offline   Reply With Quote
Old 12-07-2006   #8 (permalink)
Limited Access
Mine does the same thing, on the right side. I only noticed it because of the soot stain on the header pipe. I tried tightening the clamp but it had no effect. If I ignore it I'm sure it'll go away.
Motley is offline   Reply With Quote
Old 12-08-2006   #9 (permalink)
Mine does the same thing, but I am thinking about using saline instead of silicon.
urquel is offline   Reply With Quote
Old 12-09-2006   #10 (permalink)
Mine leaks too. I know from the small black stain. I ignore it. I'm not motivated enough to pull it apart and seal it, but would probably do so if I had to take it apart for another reason.
Marty
Small oil leak Trotts Tiger Workshop 2 10-14-2007 01:01 PM
small oil leak trav13 Twins Technical Talk 1 10-09-2007 01:13 AM
Small oil leak jcline8 Twins Technical Talk 2 07-03-2007 11:28 PM
small oil leak Triple_Rider Speed Triple Forum 4 10-27-2006 12:28 PM
Triumph High Mount Exhaust - Small leak ken750f Speed Triple Forum 8 10-08-2004 09:42 AM
