» Links |
12-05-2006
I want to lower the stock front in order to give the bike's lines a more even look.
How much can you slide the forks up without jeopardizing safety, if at all?
I tested it out and it looks killer, but I want to be sure I'll be safe before keeping it that way and getting on it...
Thanks!
[ This message was edited by: mase on 2006-12-04 23:46 ]
Paul Smart Replica
52' pre-unit thunderbird bobber/board tracker
69' CB350 cafe
Paul Smith Multi-Union
People50
Formula Extreme Favorite Bike: My Bonneville of course
I remember a few months ago this coming up and it seemed that Brent over at NewBonneville knew how low, seems an inch was too much and maybe I recall 1/2 inch was the max before you risk horrendeous woe. Perhaps someone with better memory than I could chime in????
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
12-05-2006
Site Supporter Retired Legend Favorite Bike: 904cc Bonnie w/magwheels
the general consensus is 10-15mm is safe enough...watch your horn though, if you lower it too much it will hit the front fender, especially if you have a larger aftermarket horn.
I solved this problem by mounting my horn under the gas tank, out sight but nearly just as audible.
12-05-2006
Look how close the horn is to the fender. The forks have lowered about 15mm. The horn WILL hit the fender on a big bump, when it hits it can severly upset the handling. READ: knock your ass down.
Here the horn is under the tank, and out of the way of the fender. It's very easy to do, no rewiring or anything. You can even use the stock horn bracket which is a flat piece of 1/8'' plate, and don't tell anyone but I used a drilled bottle cap for a washer which gave a little flex, and a single bolt...I can't remember the thread or size.
12-05-2006
Thanks guys!
Sweetmachine, you're bike is def inspiring! I love what you did to the headlight brackets and acheives a more linear look I'm trying for.
Good call on under the tank, I'll give it a look and see if I can fit the nautilus horn I have (similar to yours).
did you adjust the pre-load in the rear too?
Paul Smart Replica
69' CB350 cafe
People50
12-05-2006
Wow,
what a statement your bike makes sweatmachine guy!!!
With only subtle alterations, you've created one of the cleanest Bonnie's EVER. A chrome cam cover would be 'too much', discrete front turn signals while keeping my MUCH LOVED art deco rear indicators, and that Black headlamp housing..... jeez I Love that! Not to mention my regret for having rid myself of the Pred's..... But surprise of surprises, I find myself agreeing that some old fashion & bulbous gaiters would be unbecoming to such a clean machine.
Truly a Gentleman's Bonnie.
- 'Rider' -
Click here for a view of my Member's Album.
12-05-2006
i think i lowered mine around 3/4'' with no problems at all. had my first sweeping turn at around 100 MPH last week and it felt great. Make sure that they are exactley even though.
TJ
12-05-2006
Thanks Pat, maybe one day I'll sell it to a nice gentleman that befits your comments! Until then this bastard heathen hooligan is the pilot!
Since that photo I've installed matching turn signals in the rear, in the stock housing. I have a set of fork (dork) gaitors in my garage just waiting to be installed, I like the fat look they give to the front end.
I too love the black headlight housing, everytime I see a bonnie in person that still has the chrome headlight I remember why I painted mine.
Pat, in case you missed the thread a while back I cut 1.5'' out of the bottom of my headlight brackets and welded it on top of them, to lower the headlight, then I lowered the gauges about 1.5'' too.
Thanks for the nice comments guys. Clean and subtle was exactly what I was after...now my mission is to get 85-90 rear wheel hp out of this bad boy.
12-05-2006
Before
and after.
I have the Ikon Bonnie shocks under the tree that will be lowering the rear by 1''. I can't wait for Christmas morning to put them on!
[ This message was edited by: caspianthruxton on 2006-12-05 08:41 ]
12-05-2006
I wanna be a 'bastard heathen hooligan' too when I grow up.....
I'm mistaken for neither a gentleman nor a hooligan, giving off mixed signals instead. I haven't quite figured out if it's ME who's confused 'bout what I am.... or the rest-o-the world.
I don't think I remember catching what you did to lower stuff up front, it works though THAT'S fersure! Well..... gaiters it is then; personally I could NOT have a Bonnie without 'em. With regard to switching out the art deco's on the back.... well, they DO stick waaaaay out there. I'm fired up about altering mine to make them shorter and Blacker.
And given how much fun I had on a BMW putting 79 horsepower to the rear wheel, a Bonnie with that kind of power would be intoxicating. However I would limit my engine mod's to only that which would assure me absolute uncompromising reliability. I won't have any money to do ANYTHING though, given as I have just accepted pretty significant monthly car payments. It I do anything to promote more horsies, it'll be via an air box removal and ZARD exhaust system (if it's as good on the Bonnie engine as it's claim on Bonnie racers).
Sorry 'bout hijacking a thread about lowering the Bonnie. I'll make up for it by submitting my two-pence worth:
I lowered my FZ1, and the ONLY way I would do it to the Bonnie would be via the same method (but I won't). I lowered my Yamaha by having the internals of both my front tubes and rear shock lowered. At the same time, I changed out the springs to better match my weight, and had things revalved. The bike now handles like it's on rails, I can stick FILLED Krauser hard bags on it for a trip across the nation, and I would like to think the bike is lower.... but for MY 24" inseam, it's not. All the comfort zone of the factory's initial sag has been eliminated, and it's a FIRM ride even on the smooth tarmac. My poor riding habits (read, 'not very smooth') is now arrested and not telegraphed to the road when I'm pushing the envelope... and THAT'S a good thing. But even with a lowered saddle and an inch lower front & rear, I'm still tippy-toe'ing one foot at a time.
All I'm suggesting is that if you're gonna mess with the factory geometry of a machine, there are compromises that will be made. The bike may 'feel' fine, it may even 'feel' like it's got a lower/better center of gravity, but with an altered suspension it may not rear it's ugly head and act up until the very WORST moment. I suppose if you ride smoothly, never touch down, and ride at sane speeds, your bike might behave. BUT that unannounced decreasing radius with a dip right at the apex..... even at a "safe" speed, could get real ugly REAL quick.
I'm sorry, I just want folk to be scared of mod'ing the suspension for cosmetic reasons.
Rant off.
:hammer:
- 'Rider' -
