Abrupt Throttle Response - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearHonda PowersportsMotorcycle.comOntario Tourism
Old 12-04-2006, 07:06 PM   #1 (permalink)
I'm the new owner of a stock 2002 Bonneville and have got a question.
Engine response to closing the throttle seems awfully abrupt (to me anyway).
Are there any mods that would reduce this effect?
Does shimming the needle jets or removing the air injection system help?
Thanks
swebb is offline   Reply With Quote
Old 12-04-2006, 07:30 PM   #2 (permalink)
bonnevillebilly's Avatar
I'm not sure what you mean by abrupt.
Abrupt , fast ,quick, suddenly.
Are you saying it slows down to abrupt. I don't know?
I know the stock set up has a delay in the throttle response.
And rejeting to bigger jets helped by giving it a little
quicker throttle response.
Bill
2001 Bonnie
1976 Bonnie
bonnevillebilly is offline   Reply With Quote
Old 12-04-2006, 07:39 PM   #3 (permalink)
a mod to the speed of your wrist will slow it down.
or speed it up.
the throttle (like pretty much all throttles) is designed to snap shut when let go of. modify how fast you close it
G
I just wanted to ride
Old 12-04-2006, 07:48 PM   #4 (permalink)
What I meant by abrupt was that closing the throttle
relatively quickly at low speed causes a sudden decrease in engine speed (expected) and then the whole bike pitches forward on the front forks.
I was expecting a smoother transition from a light to closed throttle.
The effect seems to be amplified by the soft fork springs.
It's probably just me not being used to the bike yet.
Old 12-04-2006, 08:07 PM   #5 (permalink)
It depends on what gear your in. If your at high rev's and
in a low gear she's going to lunge forward when you let
off the throttle.
Bill
[ This message was edited by: bonnevillebilly on 2006-12-04 18:29 ]
2001 Bonnie
1976 Bonnie
Old 12-04-2006, 08:08 PM   #6 (permalink)
Favourite Bike: 69 Tiger TR6R
pabonne's Avatar
Other Motorcycle: 2003 Bonneville
If you're talking about "engine breaking" one way to smooth things out is to increase the idle speed. I'm not going to pretend to know the mechanics behind it but ever since I upped my idle speed for the winter months there's less breaking (and popping, etc.) on decel. I normally keep my idle speed fairly low because I love both the popping and not having to jump on the breaks all the time.
Maybe someone more knowledgeable can explain what's going on here? Just a thought.
2003 790 Bonne (black, not Black) / 1969 Tiger TR6R (oh so sweet)
Addicted to Triumphs for over 40 years.
pabonne is offline   Reply With Quote
Old 12-04-2006, 08:26 PM   #7 (permalink)
What is there to explain? You let off the throttle ,you stop
giving the engine gas ,your in gear.
What's going to happen?
Bill
2001 Bonnie
1976 Bonnie
Old 12-04-2006, 08:29 PM   #8 (permalink)
Short version = Don't worry...it's supposed to do that.
Slightly longer version = If it doesn't do that, then you've got problems (or a two-stroke motor).
DFWBiker is offline   Reply With Quote
Old 12-04-2006, 09:50 PM   #9 (permalink)
pabonne's Avatar
Yeah, maybe it is that simple. I guess I was thinking maybe there's something about the bonnie's unique engine config (360 deg, carbs, flywheel, etc.) that makes it more noticeable or pronounced than other scoots.
Old 12-04-2006, 10:00 PM   #10 (permalink)
A lot of it has to do with the gearing.
I depend on the engine helping me slow down.
I noticed a big difference when I switched my front
C.S sprocket from the stock 17T to the 19T.
I had to get used to dropping down a gear to help slow
me down going into a corner.
Bill
2001 Bonnie
1976 Bonnie
On-off throttle response??? dkurtz Triumph SuperSports 13 07-30-2007 03:39 PM
Throttle response joeknows Twins Technical Talk 10 03-21-2007 11:40 AM
inaccurate throttle response alastairmcook Tiger Workshop (archive) 5 10-22-2006 05:16 PM
Jerky throttle response Whisperinsmith Sprint Forum 13 05-09-2006 07:53 PM
Throttle Response Richard Daytona Deliberations 4 09-08-2004 05:40 PM
