I used the Ikons front and rear and the ride is noticeably better than stock. I think the fork springs made more difference than the shock swap...not sure exactly why.
Ikon fork springs are a little shorter than the stock+spacer combination. I used a PVC pipe coupler for 1" pipe, cut in half (across the diameter, smart guy). That was about an inch of spacer; I fine-tuned it with the preload adjusters. You will need a spacer with the Ikons on a Thruxton.
I wouldn't worry much about the price diffs...if doing both ends I'd stay with one manufacturer on the hopeful assumption that they actually design them to work well together.
So long, and thanks for all the fish!
