Center Stand - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-30-2006, 03:29 PM   #1 (permalink)
Favourite Bike: Tiger 1050
I am in the process of fabricating a center stand for my T100.
I offered it up tonight and found the first problem, I couldn't lift the bike onto the stand on my own. I haven't got the angle right on the bit you put your foot on. Has anyone got a pic of a center stand down taken from the left hand side of the bike?
Many thanks,
Bob
"Those who can make you believe absurdities can make you commit atrocities"
-Voltaire
byjingo is offline   Reply With Quote
Old 11-30-2006, 07:53 PM   #2 (permalink)
Favourite Bike: 2005 Bonneville T100 (B&W) - Chromed like a Harley
raproe's Avatar
Bob, this may or may not help you, but maybe someone else can use it.
I also made my own center stand except that I made it as a tool rather than a permanent stand. The disadvantage is that it takes a minute or so to take on and off and of course it won't be there on the road. The advantages are that it is pretty simple and has a much wider stance than the stock stand so it makes a very stable work stand. Some people have made even simpler stands but this one attaches to the regular stand attach points so it is out of the way when you want to get to the oil filter. I designed it so that the rear wheel is just still on the ground (for oil changes etc.) and I just put a 1/2" board underneath to lift the wheel up for chain servicing.
It has plenty of leverage to get the bike up and works very easily. An adobe .pdf file with photos and drawings is here.
"....by its very nature, a single-tracker is in unstable equilibrium, i.e., it cannot, when stationary, stand up by itself."
raproe is offline   Reply With Quote
Old 12-01-2006, 02:21 PM   #3 (permalink)
Wow, that is so simple but effective too. I had made a stand with 1/2" water pipe but it took three of us to lift it onto it.The foot lever wasn't right. I have been modifying the angle at which the push down bit fits onto the upright but I may well s***** the whole thing and make one like yours. I too want it for workshop servicing etc. not as a permanent attachment. Thanks very much for sharing your design.
Bob
-Voltaire
center stand or rear wheel stand? SlackCat Speed Triple Forum 16 05-08-2006 03:53 PM
Kick Stand vs. Center Stand Tooth Maintenance & Workshop Talk 9 10-19-2005 10:02 AM
Center stand and/or Swingarm stand or jack rprockey Hinckley Classic Triples 3 08-17-2005 07:21 AM
Paddock stand vs. center stand questions Solace Sprint Forum 6 04-01-2004 10:31 PM
Center stand and side stand wanted Sprint Forum 1 01-21-2004 09:38 PM
