Old 11-28-2006   #1 (permalink)
listo's Avatar
Other Motorcycle: 1976 Honda CB550 Cafe
Got around to installing the the BC Predators and Airbox removal kit and fender elim kit on my brothers thruxton today. Removal of everything was very straight forward and the install also straight forward. Removed the air injection too. Would have been nice to have some instruction to go by on some things. The newbonneville instructions helped abit. Only hangup was putting the rear tire back on. Couldn't get the wheel spacers to fit and it took about 45 minutes to finally get it all setup.
Other than that the Thruxton looks and sounds awsome with the new pipes and fender gone. Rode it and it really needs the jet kit installed. Wouldn't run over 4k and alot of backfiring. Still need to loosen and re-tighten the right pipe as it has a small air leak. Ran out of daylight so the jets will wait another day.
08' S3 Black
76' Honda CB550F cafe
listo is online now   Reply With Quote
Old 11-28-2006   #2 (permalink)
Favorite Bike: My one-and-only '03 Bonne
pabonne's Avatar
Sweet upgrade. :upthumb: Get the carbs set and it should feel like a completely different ride.
Your brother's bike?? When you gonna join him? :-D
2003 790 (black, not Black) KARK'd, K&N Cones, Staintunes, 130/42 jets, 2.5 turns out, BC Superbars, CRG LS mirrors, Generic Rubber, 16t
Why? Too many H-D's.
pabonne is offline   Reply With Quote
Old 11-28-2006   #3 (permalink)
Favorite Bike: '06 Bonneville Black
Other Motorcycle: '89 FXR
What jets do you have ?
I'd expect needing around a 145/150 main and 42.5 to 45 pilots with that setup.
Hated By All....cause thats just how it is.
SCCTrim is offline   Reply With Quote
Old 11-28-2006   #4 (permalink)
listo's Avatar
Yeah, the sound is truly awsome compared to stock. Were going to use the supplied jets, 45 pilots and 145 mains that BC sent. Probably do it this weekend when I have time again. Any hints on the jet replacement. I've been reading here but not sure on the entire thing. Tools,etc.. needed basically.
08' S3 Black
Old 11-28-2006   #5 (permalink)
Retired Legend
sweatmachine's Avatar
all you need to know
Old 11-28-2006   #6 (permalink)
Retired Legend
just as a reference, I have the same motor and setup, I just tweaked my jetting and it's running better than ever:
42 pilots, 1 shim on the needle (down from 2 shims), and 155 mains.
Yours should be fairly close to that. My needles are the same as yours. I think I could use one size larger mains, but it's running solid now.
Old 12-03-2006   #7 (permalink)
listo's Avatar
Finished up installing the supplied 45 pilots and 145 main jets. Super easy to do. I wound up just removing the carbs as it was easier. Anyway.
THE BIKE RUNS AWESOME. The 45 / 145 combo make the bike run like a raped ape. Pulls strong and no dips throughout the entire RPM range. Just ran it between 1-4 gears as it was just in my neighborhood and its great. No stuttering or backfires, just fast pulling all the way to redline. Very happy with the results. The Predators sound great btw .. I don't think we'll need to jet up any higher or mess with the needles. Going to have the dealer give it the 1000 mile tuneup and sync the carbs if needed but I don't think it will need it.
Thanks
Chris
[ This message was edited by: listo on 2006-12-03 18:10 ]
08' S3 Black
Old 12-03-2006   #8 (permalink)
Retired Legend
mine ran good, then I added one shim to the needles and it ran much stronger at roll-ons and midrange...it's easy to do, and cheap.
I've got 2 extra shims, PM me your address and I'll mail them to you free!
Which airbox removal kit? Kendall Twins Technical Talk 18 07-08-2007 05:31 AM
Which airbox removal kit? Rat_bastard Twins Talk 21 04-04-2007 06:13 AM
airbox removal kit? coma4by Twins Technical Talk 3 10-08-2006 09:54 PM
What Airbox removal kit? setts Club Cafe 5 07-27-2006 08:07 AM
Spring Mods--Predators, Airbox Removal, AI Removal idaho_thrux Twins Talk 6 04-09-2006 03:30 PM
