BikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 11-28-2006   #1 (permalink)
stu
Favorite Bike: 1952 Vincent Black Shadow
Other Motorcycle: 2002 Bonny
Extra Motorcycle: 2002 Sprint ST
I had a simple job today, replace my chaincase with a chrome unit I purchased off a member recently. Figured aboout an hour job. Drained the oil, removed the cover with no problems. Cleaned off all old gasket, installed new gasket, case, bolted everything up, replaced oil-great! Starter wouldn't turn!
Drained oil again, removed cover, found the 3" shaft the idler gear runs on had come out of its bore in the back of the case, and the gear was jammed into the case. Managed to get it free, couldnt get shaft back in without filing out burrs in hole. Finally got gear installed properly, put case back on, starter checks Ok, put oil back in- s***t, forgot to put the gasket back. Drain oil, take case off, instal gasket, put all back together, fill with oil, realise wave washer that goes on end of idler shaft is sitting in the bottom of the oil pan. Redrain oil, take case off, install washer, refill with oil, realise I forgot seal washer on oil drain plug. Drain oil, replace washer, refill. It is now 6 hours since I started. FRom now on, dull alloy suits me fine.
Stu
TORs, NARK, thruxton needles, 140mains.40 pilots 2.75 turns out, procom igniter, 17T
stu is offline   Reply With Quote
Old 11-28-2006   #2 (permalink)
bonnevillebilly's Avatar
Man.... that sounds like a real bad day
Ah... but look at the bright side.
I bet your real good at draining the oil now.
Bill
2001 Bonnie
1976 Bonnie
bonnevillebilly is offline   Reply With Quote
Old 11-28-2006   #3 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
Stu,
At my age that sounds more normal than not--maybe it's just your punishment for living where you have good riding Wx the whole year. :-D
Larry
Larry
Old 11-28-2006   #4 (permalink)
Favorite Bike: My Bonneville of course
Thanks, I needed a laugh, I mean sorry for your debacle. We have all had our moments like this. There are some days it is best to not crawl out of bed, then again those are the days that make a good story, at least you didn't really screw anything up, just lost time but better than sitting in a cube somewhere wishing you were riding.
Happy riding with your shining cover!
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
vertwrks is offline   Reply With Quote
Bike was total - Help Triumphy Twins Technical Talk 14 02-23-2007 02:00 PM
A Total Black Out rmak Twins Technical Talk 2 01-13-2007 12:22 PM
2006 mileage total upNorth Biker Hang-Out 40 01-06-2007 08:45 PM
Total thanks to all at Triumphrat stwanted Sprint Forum 7 01-01-2007 12:20 AM
total shut down on my sprint1050 nehpetsthegrey Sprint Forum 3 12-17-2006 07:06 PM
